It is currently Sun Nov 16, 2025 6:27 pm
 Post subject: Timing Set?
PostPosted: Fri May 10, 2002 11:46 am
I will be pulling the balancer to replace the timing cover seal, so I may as well replace the timing set. What timing sets are available and what do you recommend? Any with a multi-keyway to change advance/retard?
TIA
Mitch
m5black@aol.com
 Post subject: Re: Timing Set?
PostPosted: Fri May 10, 2002 2:23 pm
Mitch,
I got my Cloyes set from Clifford Performance, although as I found out here, there are less expensive alternatives available.
To advance or retard the cam, use the Mopar Performance offset bushing set PN# P3690936. This includes 5 bushings: 2,4,6,8 degree and an on-center bushing. Drill the cam gear to add the bushing.
Gilly
tlg225ccr@aol.com
PostPosted: Fri May 10, 2002 5:12 pm
: I will be pulling the balancer to replace the
: timing cover seal, so I may as well replace
: the timing set. What timing sets are
: available and what do you recommend? Any
: with a multi-keyway to change
: advance/retard?
The Cox Boys have the all steel, multi keyed dbl. roller set.
(614)268-9920
PostPosted: Fri May 10, 2002 6:35 pm
: advance/retard?
: TIA
: Mitch
Cloyes double roller P/N is S338
shearnstable@earthlink.net
Users browsing this forum: Google [Bot] and 13 guests
