It is currently Sun Nov 16, 2025 11:25 pm
PostPosted: Wed Jan 10, 2024 5:57 pm
Car Model: 1965 Dodge Polara
Does anyone have any pics of a mid to late 60's C-body front subframe showing mounts for a /6 ?
Or would you know the hole dimensions (distance between holes) ?
I've got what I think is a '65 - '68 front sub frame that I think has /6 mounts and likely would have come from a Fury. If this is true, I'm in a dilema because I wanted this for a small block and there seems to be no adapter brackets possible for this.
But if I'm wrong, let me know.
Some people think this might be an early frame, maybe 64 or 65 and the mounts might be for a 413?
PostPosted: Sat Jan 13, 2024 4:27 pm
I thought that like a truck, the frame/cross member was the same no matter what engine and the difference was made up by the motor mount brackets that bolted up to the block for the different engine options
