It is currently Sun Nov 16, 2025 6:27 pm
 Post subject: harmonic balancer
PostPosted: Sun Jun 03, 2001 8:45 pm
Where can I find a new harmonic balancer for my SL6-225? Mine came apart when pulling it off the engine and I don't feel it is usable.
vmted@sprintmail.com
 Post subject: Re: harmonic balancer
PostPosted: Sun Jun 03, 2001 9:38 pm
: Where can I find a new harmonic balancer for my
: SL6-225? Mine came apart when pulling it off
: the engine and I don't feel it is usable.
There is a place in California called "Damper Doctor" that rebuilds them. If you use the "search" function, the address may be in an old post on here.
aschumers@aol.com
PostPosted: Mon Jun 04, 2001 9:15 am
: There is a place in California called
: "Damper Doctor" that rebuilds
: them. If you use the "search"
: function, the address may be in an old post
: on here.
If a quick way out is needed, I have a "pile" of good used ones for "cheap" I will need to know the year of the engine and where the timing mark is located.
(BTW...Next time, use the correct damper puller to take these off, as you found-out, "jaw type" pullers just pull the outer ring off the damper)
PostPosted: Thu Jun 07, 2001 3:44 pm
I was digging around and found the address for Damper Doctors.
1055 Parkview Ave.
Redding, CA 96001
aschumers@aol.com
Users browsing this forum: Google [Bot] and 13 guests
