| 1962 Valiant Station Wagon https://mail.slantsix.org/forum/viewtopic.php?t=67103 |
Page 8 of 14 |
| Author: | Greg Ondayko [ Thu Feb 22, 2024 11:10 am ] |
| Post subject: | Re: 1962 Valiant Station Wagon |
Hi Dan, I never did buy one of those reports. I probably never thought at the time that I would find one, let alone 2 '60-'62 valiants that I would eventually own.. Or maybe I was so uneducated that I was never interested in one, that is until I rode in one. They are quite the engineering feat. And just goofy enough that I like ' em a lot. Thank you for shedding some er, uh, ahem, I know you have never heard that one before, so feel free to chuckle with the eeeeeeeeeeevillll villain cackle or not. Thanks for the info! Greg |
| Author: | SlantSixDan [ Fri Feb 23, 2024 10:40 am ] |
Blue battery pan is good for 0.25 off your 1/4-mile ET on the strip, and about 1/2 mpg on the street. Scientifical fact. |
| Author: | Rick Covalt [ Fri Feb 23, 2024 1:41 pm ] |
Quote: good for 0.25 off your 1/4-mile ET on the strip
Then I'm putting one in my race car!
| Author: | hyper_pak [ Fri Feb 23, 2024 5:15 pm ] |
psychological horsepower |
| Author: | SlantSixDan [ Fri Feb 23, 2024 7:57 pm ] |
Quote: psychological horsepower
That's the kind Chrysler used when the Slant-6 was new. That "101 horsepower" rating for the new 170 engine sure was convenient for the marketers, eh! A nice li'l one-up over a hundred horsepower. You get more…with Valiant! And the 225's nice, tidy, neat, ends-in-5 "145 horsepower" rating, again real nice for the marketers. In heavy-duty trucks and industrial applications, the same 225 with the same camshaft and a slightly bigger carburetor was rated 127 horsepower, pretty much bang-on with what GM found when they bought a 1961 Lancer, took the (aluminum) 225 out of it, and extensively tested it. My theory: horsepower numbers sell cars, and once the car's sold that number is irrelevant. But truck/industrial buyers have a real need to know what they're getting, hence the less-sexy, more-accurate numbers shown to them.Psychological horsepower, then. |
| Author: | SlantSixDan [ Tue Feb 27, 2024 12:37 pm ] |
Hey, interesting! Is the new DMT hood insulation pad die-cut like the original, with the triangular sections cut partway through the material to nest up into the underhood webbing? I ask because up to now all the repro '60-'62 Valiant-Lancer pads have not had that, so they don't nest with the webbing and take on a poofy/tufted appearance once clipped to the hood. I'm not seeing any of that on your install, hence my interest. |
| Author: | Rick Covalt [ Tue Feb 27, 2024 4:33 pm ] |
What is the round hole for in the hood bracing for? |
| Author: | Greg Ondayko [ Tue Feb 27, 2024 5:15 pm ] |
Quote: What is the round hole for in the hood bracing for?
Radiator Cap Clearance I believe.
| Author: | Greg Ondayko [ Wed Feb 28, 2024 5:06 am ] |
Quote: Hey, interesting! Is the new DMT hood insulation pad die-cut like the original, with the triangular sections cut partway through the material to nest up into the underhood webbing? I ask because up to now all the repro '60-'62 Valiant-Lancer pads have not had that, so they don't nest with the webbing and take on a poofy/tufted appearance once clipped to the hood. I'm not seeing any of that on your install, hence my interest.
Hi Dan, I was unaware that anyone even made reproduction hood pads for this car in North America. I am sure you know or can find out. I just did not want the hassle of doing all the research, as I assumed they would be hard to find and/or source from any place other than Australia or Argentina. Because of my assumptions, I took the original one off of the hood, with the semi-die cuts on the topside that faces the metal hood, and placed it engine side down on a sheet of 8?' x 4' generic hood insulating pad that I bought from DMT, and then traced the original part's shape onto the new material and then cut it out and poked some holes in where the clips belong. I believe that the side that is supposed to face the engine compartment is facing the metal underside of the hood ( I did it backwards, not on purpose, just because I am a dumbass) and did not have enough raw material to do another tracing. and so I installed it that way. So due to my ineptness and lack of restoration knowledge, it is not poofy and flat the way it should look. So maybe restoration ineptness = restoration correctness??!?! (in this case) Greg |
| Author: | SlantSixDan [ Wed Feb 28, 2024 12:47 pm ] |
Repro pads are readily available in North America from REM Automotive, listed in the parts sources post. Part number is PLY-HIN-040 or DOD-HIN-075; same item under two different part numbers. No die cuts for the hood webbing. Shop around; different REM dealers have different prices on it. AFAIK it's not available in Australia, and I know it's not available in Argentina (I sent two of the REM items down there last year, to the guy who would know if it were available locally to him). Attachment:
| Author: | Greg Ondayko [ Mon Mar 04, 2024 6:46 am ] |
Quote: Repro pads are readily available in North America from REM Automotive
Good to know, I was too lazy to look and made my own. oh well, now I know. Thank you again! |
| Author: | SlantSixDan [ Mon Mar 04, 2024 1:04 pm ] |
Izzit gonna still have the 3-on-the-tree when you're all done? |
| Page 8 of 14 | All times are UTC-08:00 |
