Best Times
https://mail.slantsix.org/forum/viewtopic.php?t=5579
Page 9 of 12
Author:  slantzilla [ Thu Jun 09, 2011 5:28 pm ]
I had the motor out last year and put on a milled head. I also re-degreed the cam and found it a tooth too far advanced. :oops:
Compression is now a true 11.5-1. It seems to like it. :wink:
Author:  ceej [ Mon Jun 27, 2011 9:36 pm ]
***9 Second Zone***
9.85 @ ??? The Drakes, 1938 Simca
9.93 at 132 Charles Myers, Plymouth Arrow, 6/21/2003
9.97 @ ??? Cox Bros, 66 Dart
***10 Second Zone***
10.19 @ 129 Mike Jeffrey and Blaine Mueller's "Buzzin' Half Duzzin' 1968 Valiant
10.5 @ 127 Will 67 Barracuda methonal & nitrous with Cam2 enrichment July 2004
10.74 @ 127.47 - 1.57 60', turbo66valiant, 66 Valiant Signet, 2800# w/o driver, turbo, intercooled, 727, 2.94, AV gas, July '10.
***11 Second Zone***
11.02 @ 120.56 Shaker223, 1.57 60', Turbo/FMIC, 1970 Swinger, 2.76 gear, 255/60/15 radials, 3300lbs Race Wt. Sept 2010
11.363 @ 114.47, Exner Geek, 62 Valaint, 150# lighter than Guzzi, 904, 4.56, Webers, on gas at Cedar Falls, IA 10/16/10
11.500 @ 117.725 MPH (not correct) (NEW B GAS RECORD) Sacramento Guzzi Mark 9-12-2010
11.54 Dave Mueller Alchohol Injected (C/Alcohol Record)
11..65 @ 114.5 Nick Stamm (turboram) 3700# 86 ram turbo NO2 to launch
11.77 @ 116.29 Shaker223, 1.83 60', Stock Slant 6 with turbo, 1970 Swinger, 2.76 gear, 215/75R/14 radials, 3500lbs Oct 2009(retired)
11.88 Ron Hamby at Hamilton Oh. 2004 '66 Dart on NOS
***12 Second Zone***
12:001 @ 110.07, 1.61 60', Slantzilla, '66 Valiant post car, 232 ci Slant, Keith Long full manual 904, 3.91, 150 Top Gun shot, 3250#, Street legal.
12.02@ 107mph Ron Hamby at ClayCity Ky. 2008 '66 Dart on Alky---
12.33 at 107.88, Samoa, SwinginSixAric
12.43 @ 102 mph at Clay City 10- 10- 09 Ron Parker
12.64 @ 105, Doctor Dodge - 62 Lancer, Sacramento 2010
12.941 @ 105.50, Old6rodder (Dick Sappington), HA/GR, "Barn Job #18", ANRA finals '09
12.98 at 101.03 at Redding, "Wayne's World" 170 cu inch (on gas) 62' Valiant -Wayne Erickson-
***13 Second Zone***
13.102@ 99.65 Charlie Schmid, 66 Cuda 170 cid May 23, 2011
13.39@96 sgtmcd42, Crooked 6, red light lifted @ 1000'
13.41@ 96.20 Charrlie Schmid, 66 Valiant 225cid
13.469@ 99.137 PJ Jesiolowski Sacramento Raceway May 2011
13.58@ 100 Kidd 62 Valiant, MATS 2009
13.58 @ 99.46, 1.82 60', 8.63 1/8 mile, Exner Geek, 62 Valiant, Street Driven, 2800#, A833OD 3.73 gas, May 2011
13.74 @ 94.7, Lou Madsen (Dart270), autoX tires, 904, 3.25 rear, 2670 lb racewt - Project V - Clay City Race 10/08/10
***14 Second Zone***
14.061 @ 96.58 Ryan Covalt '72 swinger daily driver 3330# (50 shot) Mason Dixon 7/30/2010
14.15 @ 91.02 Crazy Dart (converted from 1/8mi) 67 Dart,904, 3500 stall, 4.30 gear. 5500 RPM.
14:19@96 - Little Red Piggie (Slantzilla) on muscle only- Kearney, NE 6/4/11 race - D/gas record.
14.206 @ 94.76mph 2.05 60' METALSKIN draw thru turbo slant (9psi) AP5 valiant 2.9
14.30 @ 96 MPH Lou Madsen '64 Dart 270 in street/strip trim in 1997 at Pomona Dragway (904w/3400 stall, 14" Radial TAs, 60 over cast pistons)
14.57 @ 94.6 MPH, Lou Madsen '64 Dart 270 in street/roadrace trim, 2009 at Mason-Dixon Dragway (T5 trans, 16" autoX tires, 60 over cast pistons)
14.743 @ 89.81, 1.931 60' Bren67Cuda904, 258 ci Slant (Eileen) 3400 lbs with A/C, Gear Vendors, Full interior including Child car seat, 8 1/4, 3.55
14.79 @ 93.56 Greg Ondayko
14.84 @ 91.22 Ryan Covalt 72 Swinger 3330# Daily Driver/ Mason Dixon May 31,2009 4.30's, 4 sp.OD no nitrous
14.975 @ 89.70mph "6 Pac To Go" Fopar's Mopar '63 Dart GT Woodburn 7/19/09
14.98 @ 95.29MPH - Turbo'ed '68 Dart street car - Lou Madsen - 2011 Kearney race, 8.5 psi boost max T60-1 turbo, no intercooler or water/meth inj, 3.55 gears, A500 trans w/2200 stall, 3410 racewt, D/Unlimited record.
***15 Second Zone***
15.024 @ 90.63 Ceej, Hooptie, Woodburn 7/18/10 and 6/25/11 exactly the same E.T.!
15.12 sergio 7/11/9 samoa stock engine 3.91 hedder ,5002 BB converter
15.20 @89 Joel Harris 69 Valiant, 225 stock bottom end, .100 off head, 2bbl, pump gas, mopar268 cam, headers, stall, 3.91, 904, 2750# w/o driver, mostly stock driver
15.34 @ ?? Brian '74 Duster,1971 225 block ,.100 off blk, .100 off head,MP 528" lift cam with 284 duration, 904,4.10
15.39 @ 87.32 Fopar May/4/08 3400lb 53 Ford 225 bored .030 .090 off head custom cam custom headers 904/4.11's
15.39 @ 87.7, Lou Madsen (Dart270) '90 Slantkota with 258" engine, mild cam, 3.23 gear, 2400 stall, 3310 racewt, Clay City Race 10/09/10
15.40 @ 89 mph Lindross, roadster
15.501 @ 88.32, SV162, low comp head, 3.7 diff, May 2008
15.73 @ 88.32, SV162, high comp head, 2.92 diff, Sept 2009
15.6 @ 90 MPH - '68 Dart street car - Lou Madsen - 1996 at LA Cty Raceway
15.82 @ 84.32 1974Duster Kev- Converted from 1/8 mile numbers
15.855 @ 87.25, Rob Simmons, '73 "GodsRods" Duster, 28 May 06 @ SGMP, just under 2,785 #
***16 Second Zone***
16.18 @ 84.26, SV162, low comp head, 2.92 diff, Feb 2009
16.281 @ 82.64 DusterIdiot, Medford, Hpak Duster Holley Annular 600, 3400 lbs
16.35 @ 81.3 70valiant', 3.23
16.59 at 81.68mph TRYSIX '65 Coronet 4dr, Isky cam 228/448
16.707 @ 82.11 Mike Andreas,225 cid block +30. Stock pistons .100 off the deck. Isky 448 lift, 4 speed
16.868, 80.06 MPH J. Skinner '67 Valiant 100 3-speed, stock short block
16.89 @ 78.49 3.23open 75 duster (Wicked/six)
***17 Second Zone***
17.03 @81 MPH. Casey Reed R688 '70 Dart 225/904, 4-BBL, headers. 2.76 open.
17.13 @ 77.30 aaron downing 225, 904, 4-BBL, headers, 390 holley, 3:55 suregrip
17.20 @ 85 The Black Sheep
17.27 @ 79.03 Featherduster76(converted from 1/8mi) 71 Duster 225/904
17.29 @ 78.66 Rhonda Amis '66 Valiant Signet 200 225ci,904 MATS 2009
17.44@78 Slant Cecil '68 Signet 225, 904 ,2975lb w/driver ,140K mile motor with 6x1 header, BBD, electronic ign ,4400rpm shift
17.69 @ 75.78 THOR 65 Dart GT "Madeline"
17.72@77 Nick Bowman 1970 Plymouth Duster 2bbl-904-3.23
17.88 @ 77 Allen Dutra 66 Dart Station Wagon "tow car" 1 bbl 260 stroker w/ 3.23
***18 Second Zone***
18.312 @ 72.31 Vallyant
18.705 @ 73.41 The Hard Way '74 Dart 4 Door 198 Auto
18.832 @ 72.82 Dodgegirl
18.763 @ 72.26 66 Dart GT Convertable, Super six, HEI, 3.23, 904
18.766 @ 70.69 Mike'68Dart, Aug 28, 2009
***19 Second Zone***
19.05 @ 73 Davids63Dart, September 2007
19.21 @ 70 Doc, 65 Dart GT Convertible, stock alm block 225 ,1bbl
Carter, Dutra dual exhaust, 904 auto. trans., 2.94 8 3/4 rearend.
19.26@68 77Volare Wagon, stock, supersix, 833-od
19.35 @ 69.85 THOR, '74 Swinger, Redding Dragstrip (Stock Cast crank-juice engine... stock 2.76:1 "SG") 10/25/08
19.37 @ 69.77 Aggressive Ted, '74 Swinger, Pacific Raceways
19.52 @ 69.26 Slanted66, Altitude 5300 ft (Headers, Isky cam, 1bbl, 904, 3.23s)
19.6 @ 71 eightymopar , 1980 Cordoba
19.78 @69.56 1980volare, 1980 volare,bbd 2.76,28" tires,stock exhaust.
***20 second Zone***
22.18 @ 60.6mph 72polara, '73 /6 Swinger stock and wore out
Author:  ceej [ Mon Jul 18, 2011 9:26 pm ]
***9 Second Zone***
11.436 @ 115.51 mph at A Gas weight, Guzzi Mark 7/16/2011, Samoa Dragstrip
14.953 @ 91.26 MPH Ceej in the Hooptie, Samoa 7/16/2011
Author:  slantzilla [ Sun Aug 07, 2011 12:49 pm ]
***9 Second Zone***
13:82@99.8-The Little Red Piggie- Motor only-RT 66- 8-7-11
Author:  ceej [ Sun Aug 14, 2011 8:55 pm ]
***9 Second Zone***
14.937 @ 91.48 MPH Ceej in the Hooptie, Woodburn 8/13/2011
14.937 @ ?mph "6 Pac To Go" Fopar's Mopar '63 Dart GT Woodburn 8/13/11
Author:  Kidd [ Mon Sep 05, 2011 10:13 am ]
***9 Second Zone***
12.77@104 Andrew Howard,62 Valiant (Mr.Loud) Sacramento, CA.2010
Author:  Fopar [ Thu Sep 08, 2011 6:23 pm ]
***9 Second Zone***
14.937 @ 89.74 mph "6 Pac To Go" Fopar's Mopar '63 Dart GT/stock convertor Woodburn 8/13/11
Author:  Mike'68Dart [ Sat Sep 10, 2011 5:11 pm ]
***9 Second Zone***
18.281 @ 72.99 Mike'68Dart, Sept 10, 2011
Author:  805moparkid [ Thu Jan 05, 2012 7:17 am ]
***9 Second Zone***
14.25 @ 91.5mph 1.91 60' 235ci, 904TF/3500 4.86's 68 SS Dart 805moparkid
Author:  Dart270 [ Sat May 19, 2012 7:37 pm ]
***9 Second Zone***
14.395 @ 97.86 MPH, Lou Madsen, '68 Dart 270, A500 OD w/2300 stall, 3.25 Ford 8" tracloc, 245/45-16 autoX tires, 9.5 psi boost, no intercooler, meth/H2O injection, 3450 racewt, Mason-Dixon race 5/19/12, D/Unlimited record.
Author:  Rick Covalt [ Mon May 21, 2012 1:00 pm ]
Post subject:  Added my Valiant
***9 Second Zone***
14.755 @ 89.48 , 2.003 60', Rick Covalt 65 Valiant, 3.91, Automatic, 2800 race weight, 275/50 drag radial, .490 cam, 8.9 CR, 1st race, no tuning
Author:  classic ap6 [ Mon May 28, 2012 3:13 am ]
***9 Second Zone***
15.9 @ 85 classic ap6 from oz, 3.23, may 2012
Author:  Mike'68Dart [ Thu Jul 12, 2012 9:47 pm ]
***9 Second Zone***
17.73@75.89 Mike Bjerklund 1968 Dart 4dr 1bbl-904-3.23 Woodburn 7 Jul 12
18.788 @ 71.35 Chase Simmons '74 Duster, Woodburn, OR 23 June 2012
22.18 @ 60.6mph 72polara, '73 /6 Swinger stock and wore out[/quote]
Author:  Rob Simmons [ Tue Jul 17, 2012 4:01 am ]
Post subject:  Ron Hamby's Best Times updated
***9 Second Zone***
11.14 Ron Hamby at Hamilton Oh. 2004 '66 Dart on NOS
11.893 Ron Hamby at Clay City, KY 2011 '66 Dart on Alcohol
Author:  Dart270 [ Tue Aug 14, 2012 8:52 pm ]
Post subject:  Lou in 68 turbo Dart at Woodburn, OR 8/11/12
***9 Second Zone***
14.274 @ 99.91 MPH, Lou Madsen, '68 Dart 270, A500 OD w/2300 stall, 3.55 8.75", 245/45-16 autoX tires, 9.5 psi boost, no intercooler, meth/H2O injection, 3490 racewt, Woodburn, OR race 8/11/12, D/Unlimited record at 99.91 MPH backed up by 100.98 MPH
Page 9 of 12 All times are UTC-08:00
