| 350Z CD009 Six Speed Swap https://mail.slantsix.org/forum/viewtopic.php?t=59484 |
Page 9 of 11 |
| Author: | Tim Keith [ Sat Apr 06, 2019 10:29 pm ] |
| Post subject: | Re: 350Z CD009 Six Speed Swap |
Any updates on this effort ? |
| Author: | THOR [ Sun Apr 07, 2019 10:56 pm ] |
Yes, updates please! ~THOR~ |
| Author: | casedawg [ Thu Jun 27, 2019 10:31 pm ] |
I'm moving my car into some space at my machine shop this weekend to start working on getting the transmission mounted. I have sub frame connectors to weld in that I'm going to use to mount the transmission crossmember to. Then I can button up the tunnel. I'll post some pictures once I make a little more progress. |
| Author: | Greg Ondayko [ Fri Jun 28, 2019 4:51 am ] |
Good to hear! Keep at it. Greg |
| Author: | Killer6 [ Fri Jun 28, 2019 1:39 pm ] |
Cool deal!! Still have My eye on this, whenever You have the set-up worked out, let Us know when You can start on Our pieces!!! |
| Author: | Dart270 [ Tue Jul 02, 2019 4:54 am ] |
Cooi. Happy to send $$ for parts/materials whenever... Lou |
| Author: | Killer6 [ Mon May 04, 2020 8:05 am ] |
OK, ....it's that time, any updates Casey??? Still interested......hope all is well with You & Your's........ & that goes for all Members as well....... |
| Author: | Killer6 [ Tue Feb 02, 2021 12:36 pm ] |
OK & alright, it's a new Year, & My obligation to give this thread a bump! If You're out there Casey, hope You & that young family of Yours are doing well! I am still interested in this setup, let Us know what's goin' on, peace Brother! |
| Author: | Charrlie_S [ Tue Feb 02, 2021 3:55 pm ] |
casedawg hasn't logged on since Fri Jun 28, 2019 12:33 am |
| Author: | volaredon [ Tue Feb 02, 2021 4:44 pm ] |
Ive seen some blurbs online different places using (yeah I know a 5 speeed, not 6) a W58 and adapting it to different engines, it is an "AISIN" brand trans largely used by Toyota.... If I could get past "a Toyota 'ANYTHING' in my Dodge"? I'd think of trying that idea.... I had tripped across that thought when scoping out my Volare build (which is stuck in neutral) My "hangup" is that I wouldn't take a Toyota anything as a daily driver even if it were free........ not sure I knowingly want parts of one in my vehicles, either I thought about it again last fall as there was a W58 trans on CL then....... |
| Author: | Dart270 [ Tue Feb 02, 2021 7:01 pm ] |
Seems like there was a place in Australia (Castlemain Rod Shop?) that made an adapter plate to put a W58 behind a Slant. I would have no trouble with Toyota parts in my car if they are decently easy to source/repair and reliable (pretty much a given with Toyotas). Lou |
| Author: | Greg Ondayko [ Wed Feb 03, 2021 7:36 am ] |
I would be cool with 'yota parts in my car. I have ford parts in there now - which are not really ford part they are borg warner / tremec. Does the 6 speed have a gear (5th) between the say 0.61:1(6th) and 1:1 (4th) Greg |
| Author: | Greg Ondayko [ Wed Feb 03, 2021 7:39 am ] |
Looks Like the Aussy Rod shop provides adaptors for the Aussie "hemi" 6 https://www.rodshop.com.au/bellhousings Greg |
| Author: | Killer6 [ Mon Feb 08, 2021 7:04 am ] |
Quote: I would be cool with 'yota parts in my car.
No, 5th is1:1 ,& only 6th is an OD. This is what l've always wanted, a low propshaft speed & well spaced gears deep enough to not need a high rear ratio. I plan on using the 8.8 IRS I've got with the 3.27's in it. The one thing l hate about steep gears is the extra driveline vibes. Early in this thread Casey listed the ratios.
| Author: | Greg Ondayko [ Mon Feb 08, 2021 7:28 am ] |
Quote: Quote: I would be cool with 'yota parts in my car.
No, there is no 1:1 ,& only 6th is an OD. This is what l've always wanted, a low propshaft speed & well spaced gears deep enough to not need a high rear ratio. I plan on using the 8.8 IRS I've got with the 3.21's in it. The one thing l hate about steep gears is the extra driveline vibes. Early in this thread Casey listed the ratios.I have ford parts in there now - which are not really ford part they are borg warner / tremec. Does the 6 speed have a gear (5th) between the say 0.61:1(6th) and 1:1 (4th) Greg Greg |
| Page 9 of 11 | All times are UTC-08:00 |
