| Slant 6 turbo project https://mail.slantsix.org/forum/viewtopic.php?t=54579 |
Page 10 of 10 |
| Author: | Dart270 [ Thu Mar 19, 2020 3:44 am ] |
| Post subject: | Re: Slant 6 turbo project |
I am running 14 psi (max) on my 68 Dart and it works very well and is reliable. Usually I run 11 psi on the street, which still plenty of power. Enjoy the drive, Lou |
| Author: | Greg Ondayko [ Sun Mar 22, 2020 3:32 pm ] |
Will you be machining the dampener so that it doubles as the trigger wheel? Greg |
| Author: | Thomas S [ Sun Mar 22, 2020 5:00 pm ] |
Hello Greg, Sorry can you explain a bit more.. "machining the damper so that ..etc |
| Author: | Greg Ondayko [ Sun Mar 22, 2020 5:09 pm ] |
Nevermind. I see in the second picture that you have a trigger wheel bolted in front of the damper. Thanks, Greg |
| Author: | Thomas S [ Sat Feb 06, 2021 12:05 pm ] |
Trunk [url][url=https://www.bildtagg.se/bild/xfjlppfg4x63hxged1snrfg] |
| Author: | Greg Ondayko [ Sat Feb 06, 2021 4:21 pm ] |
Nice work, Soon the frost and snow will be gone and it will be up to a Balmy 15° outside. Greg |
| Author: | Thomas S [ Sun Feb 07, 2021 7:51 am ] |
Thanks Greg, Yes the spring can be around the corner.. Fuel tap access from the trunk [ |
| Author: | Thomas S [ Tue Feb 16, 2021 5:24 am ] |
I found an quite nice gearing calculator. https://www.blocklayer.com/rpm-gear.aspx Set your gear ratio,tire size etc. And this turns up A lot of info to get, how different gearing and tire size affecting rpm and speed [url=https://www.bildtagg.se/bild/s8v44 ... 15om[/img][/url] Also this page was very interesting Learning curves a race friendly dyno graph https://dsportmag.com/the-tech/learning ... yno-graph/ |
| Page 10 of 10 | All times are UTC-08:00 |
