turbos
https://mail.slantsix.org/forum/viewtopic.php?t=3063
Page 2 of 2
Author:  Bob D [ Sun Jan 06, 2002 7:00 pm ]
Post subject:  Re: TURBO and VIDEO
: wheres a good place to look for a 3.8 turbo? i
: looked all over the internet for a 3.8 and
: was unsuccsesful in finding one. MadMax
Actually you were responding to my (Bob D) post here. I know that this can get a little confusing sometimes. For a used 3.8L Buick turbo check out <A HREF="http://www.Gnttype.org/trader/traderads ... ds.html</A>. I saw a couple there recently.
Bob D
BBobbias@aol.com
Author:  Bob D [ Sun Jan 06, 2002 7:06 pm ]
Post subject:  Re: MSD 6 BTW
: sure, how do i do it?
Hopefully Doug will chime in here and tell us. I think the easiest way is to just e-mail the pictures to him.
Bob D
BBobbias@aol.com
Author:  elam [ Sun Jan 06, 2002 7:17 pm ]
I just bought a garret turbo off a turbo coupe at the junk yard complete for $25. The man there is a good friend of mine. He has played with turbos before took me over to a few Mercures they had the same garret turbo's on the same 2300 engine as the turbo coupe. Seams like a good sourse to me they are plentiful.
melam@nxs.net
Author:  Doctor Dodge (Doug Dutra) [ Sun Jan 06, 2002 8:45 pm ]
Post subject:  Re: PICs of turbos *PIC*
: Here are some questions for anyone who knows
: anything about turbochargers. Im putting one
: on my slant6.
Madmax,
To post Picture(s) on the message board, the image needs to be "up-loaded" onto the internet.
(or it could already be posted at some website)
Once you have the on-line image, copy / paste the URL address into the Optional Image URL post box below the message field.
(It has to be the full "http://www....jpg" address)
If you don't have the PICs on the web, I can work with you to get them uploaded.
The big trick with web site PICs is to crop them down and compress the size so they download fast.
Author:  andrew [ Mon Jan 07, 2002 5:18 pm ]
go to ebay motors and look under turbocharger. There are some nice turbos there!!!
andrew wagner
Author:  andrew [ Mon Jan 07, 2002 5:29 pm ]
Yes it was from switching from the small turbo too the bigger one. Don't be ashamed It is a learning experence doing something costom. Just learn from the mistakes and move on. I had to make my headers 3 times before I got what I wanted. As for the antifreezes do you mean for the cooling of the turbo? The small .48 a/r turbo got me to 15.12 @ 89 mph which I was very happy with, but I just wanted to see how far I can take the /6. One more thing the turbos from the 2.2 and the 2.5 engines are basicly the same.
andrew wagner
: would it make any difference if it came from a
: 2.5? The thunderbirds are only a 2.3 4
: cylinder, right? Im half ashamed to admit
: but I didnt take a close look at what the
: LeBeron had in it.When you say you gained in
: th 1/4 mile, was that verses a small turbo
: or verses a stock SL6? Also, where did you
: pick up your supply(pressure) line for the
: antifreeze? Thanks for offering to help.
: You'll probably be hearing alot from me.By
: the way the car is a 1968 Barracuda Coupe.
: Ill try to e-mail some pictures of what i
: have done to your site. Yes i plan to
: intercool it, Im trying to figure out how to
: place the hoses and tubing so I dont have to
: cut the radiator support.
: MadMax
Author:  Dave Clement [ Tue Jan 08, 2002 6:05 am ]
: Yes it was from switching from the small turbo
: too the bigger one. Don't be ashamed It is a
: learning experence doing something costom.
: Just learn from the mistakes and move on. I
: had to make my headers 3 times before I got
: what I wanted. As for the antifreezes do you
: mean for the cooling of the turbo? The small
: .48 a/r turbo got me to 15.12 @ 89 mph which
: I was very happy with, but I just wanted to
: see how far I can take the /6. One more
: thing the turbos from the 2.2 and the 2.5
: engines are basicly the same.
CC used four distinctly different turbos and two different manufactures over the life span of the 2.2 / 2.5 family of turbo motors. The best choice for a slant 6 (not that it would better than a 3.8 GM turbo) would be the Garrett Unit out of an 89 and newer Inter-Cooled Turbo car as well as non intercooled 2.5 "Hi-Torque" motors . This unit had a bigger turbine housing with a 2 1/2" outlet. The worset would be the Mitsubishi turbo out of a 87-88 Inter-cooled turbo car, this was also used in some 87-92 non intercooled cars. Even in the 2.2 /2.5 engine the mitsubishi turbo is restrictive and will not provide much more than 18psi boost. The early turbo cars had Garrett's with a small turbine housing and 90 VNT cars have a variable nozzle turbo (ie; no waste gate).
The big outlet garrett unit will support 300+ HP and will get a 3000lbs Daytona into the 12's or a 2400 lbs Omni into the 11's. All of the garrett turbos are T03's.
I have run a best of 15.2 in my basically stock 89 Dyatona Shelby and with a little fine tuning similar cars are running high' 14's. This is at 14psi boost. Bumping the boost to 18psi gets these cars into the 13's.
Hot-Rod 6
dave.clement@motorola.com
Author:  Richard [ Sun Jan 13, 2002 11:02 pm ]
Post subject:  Re: turbos
what about two 1.8 turbos? Run the slant with the offy dual carb intake , two dutra exhausts, and two one.eights, like off an import (colt turbo for you purests) You could run the slant liek two individual balanced motors front 3 and rear 3. Good power pulses for the blower, Less lag, less airflow per turbo, more booste, more buted cranks = GOOD TIMES!!!!:
We need to get madmax hooked-up with Andrew!
: Check out his set-up at:
: <A HREF="http://home.earthlink.net/~mrdartgt/ind ... ex.html</A>
: Andrew is a lucky guy having access to all that
: sheetmetal fab. equipment. As he has shown
: us, now it's a "what can you think of
: next" (and have time for) development
: effort.
: DD
Richard-c@e-d-a.com
Page 2 of 2 All times are UTC-08:00
