| mapping between advance curve models https://mail.slantsix.org/forum/viewtopic.php?t=36813 |
Page 2 of 2 |
| Author: | theomahamoparguy [ Sun Aug 23, 2009 11:02 pm ] |
| Post subject: | Knock Sensor Idea. Has It Been Done Before? |
you know, I was thinking, is there any possible way that you could use a knock sensor to actually listen to an engine wile you are driving a vehicle? A knock sensor is just a microphone [that's what i've been told]. If you had a small amp. and a set of headphones maybe this could work. Afterall, the whole issue with an advance curve is to avoid "knock" . Even better would be a way to record it along with the other engine parameters at the same time. Then you could really figure out the optimum advance curves along with the saftey margine for the knock. I know this might sound crazy but I was just wondering if anyone had tried this yet? I've got a feeling that you cannot hear all the knock that is happening by listening to the engine while you are driving. I know some oldtime mechanics probably can tell when detonation occurs just by the feel of the engine and reading sparkplugs but just trying a new way to do this might reveal some interesting results. Oh well just my .02 worth. Any comments welcome!...........ENJOY!.......... |
| Author: | 66aCUDA [ Mon Aug 24, 2009 5:16 am ] |
| Post subject: | Re: Knock Sensor Idea. Has It Been Done Before? |
Quote: you know, I was thinking, is there any possible way that you could use a knock sensor to actually listen to an engine wile you are driving a vehicle?
I have a knock sensor for my set up (Ford 4.2 L) set I would be interested if someone gets this to work.Frank |
| Author: | Matt Cramer [ Mon Aug 24, 2009 9:47 am ] |
Quote: Quote: you know, I was thinking, is there any possible way that you could use a knock sensor to actually listen to an engine wile you are driving a vehicle?
| Author: | 66aCUDA [ Tue Aug 25, 2009 5:19 am ] |
Matt I would agree there. I just would want the computer to sense any knock and shut it down. Frank |
| Author: | Matt Cramer [ Tue Aug 25, 2009 5:27 am ] |
Yeah, you don't want to hit knock while tuning - I was kind of responding to a couple different questions at once. |
| Author: | theomahamoparguy [ Tue Aug 25, 2009 6:17 pm ] |
thanks for reply. how much "cruise advance/ light throttle" is a good starting point for a slant. Does the 3.4 bore need a lot of advance. . The only reason I was wondering is because I had a slant that liked to "knock" alot but the other ones I have owned did not do this. |
| Page 2 of 2 | All times are UTC-08:00 |
