| Dumb exhaust question- https://mail.slantsix.org/forum/viewtopic.php?t=38342 |
Page 2 of 2 |
| Author: | Kevin Johnson [ Thu Dec 24, 2009 1:41 pm ] |
Quote: I agree with Dan unless I free one up,and it rattles,then I wire it open and forget about it.It does get down to low 40s in Cal.Dont know why it matters but if I lived in alot colder climents I would want it working correctly.Ask Kevin Johonson and I am sure he will explain the importance and workings better.Wilfred
Thanks so much. When I owned my slant six in Santa Cruz and then Livermore, California I ran it with the Offy and Clifford Tri-Y. I did use the thermostatic hot air tube on the 429 Cobra Jet air cleaner horn. Fit reel purty. I did trot out the original setup for the smog check. As I recall it met new car specs at idle. You guys should read about the development travails of the Corvair in mountain driving. Gives you an insight into why these devices are around. Edit: 6000 rpms --- 6000 rpms |
| Author: | madmax/6 [ Thu Dec 24, 2009 9:31 pm ] |
If you fish long enough,you will get a bite,He bit.Now I gotta learn about Corvairs to make a slant work right.Wilfred |
| Author: | Kevin Johnson [ Fri Dec 25, 2009 5:45 am ] |
Quote: If you fish long enough,you will get a bite,He bit.Now I gotta learn about Corvairs to make a slant work right.Wilfred
I don't think you will learn too much from Corvairs, unfortunately. I do think you should analyze what is happening to your own personal engine when it fails instead of waiting a couple years for someone else to do it for you. Touché. Some fish do bite. |
| Author: | sandy in BC [ Fri Dec 25, 2009 7:42 am ] |
<Nasty and Uncalled For> |
| Author: | carlherrnstein [ Fri Dec 25, 2009 6:13 pm ] |
dose anybody know if a replacement bimetallic spring is available from anywhere mine doesn't turn as the engine warms up |
| Author: | SlantSixDan [ Fri Dec 25, 2009 6:27 pm ] |
The bimetallic spring was included in the heat riser repair kit, but that kit is no longer available. If yours is the round-disc type and it turns counterclockwise freely but comes to a definite stop, then springs back clockwise when you release it, you don't need a new bimetallic spring. |
| Author: | carlherrnstein [ Sun Dec 27, 2009 8:44 am ] |
thanks dan |
| Author: | powerwagonpaul [ Mon Dec 28, 2009 4:56 am ] |
is this it? http://cgi.ebay.com/ebaymotors/nos-mopa ... ccessories |
| Author: | WyoCowboy [ Mon Dec 28, 2009 9:24 pm ] |
| Post subject: | Mhcv |
| Author: | WyoCowboy [ Tue Dec 29, 2009 7:42 pm ] |
Today, I tested the operation of the MHCV, and sure enough, when the engine was first started, the valve would move counterclockwise 1/2" when the engine was revved. So then I drove it, engine ran fine, but the throttle bog was still there. After driving for 45 minutes, the bog was still there. I figure that's plenty of time to get the manifold heated. When I parked, I noticed that the MHCV was not moving at all. The heat must have expanded it too tight. A few hours later, it was free again. Is that normal? Anyhow, on to the next thing for the accell bog. At least this is working now. |
| Author: | SlantSixDan [ Tue Dec 29, 2009 7:48 pm ] |
Quote: the bog was still there.
Check your vacuum advance, and carburetor operation and repair manuals and links to training movies and carb repair/modification threads are posted here for free download. Quote: When I parked, I noticed that the MHCV was not moving at all. The heat must have expanded it too tight. A few hours later, it was free again. Is that normal?
No.
| Page 2 of 2 | All times are UTC-08:00 |
