wheel hop during shifts *PIC*
https://mail.slantsix.org/forum/viewtopic.php?t=4219
Page 2 of 2
Author:  Doctor Dodge (Doug Dutra) [ Sat Sep 28, 2002 9:22 am ]
Post subject:  Re: Wheel hop and suspension set-up info.
: Maybe I'm missing something but it appears to
: me that you're trying to swing the axle in
: two different arcs at the same time . . .
: the result may be that you've effectively
: formed a rigid geometry between the lower
: links and the leaf springs. Its like you're
: running no suspension and so its tough to
: keep the wheels in contact with the road.
Looks like everyone "pin-pointed" the possible proplem(s). You alway have to be careful when doing changes on the Mopar rear suspension system, it may look simple and baisc but a bunch of good engineering went into it's design and operation.
Here is a link to some additional info from a racecare car chassis set-up book written by Dave Morgan.
Door Slammers: The Chassis Book
Author:  kesteb [ Mon Sep 30, 2002 12:40 pm ]
Post subject:  Re: Leaf link?
: It won't behave like a four link at all unless
: the axle is free to rotate about the
: springs. If that were the case, that
: suspension geometry would give you some
: pretty severe wheel hop, so I'm assuming the
: axle is attached to the leaf springs in the
: conventional way. It looks to me like he's
: running a set of Chevy-style traction bars.
The "leaf link" was designed for classes that did not allow 4 links or ladder bars. The front portion of the spring worked as the lower link, and a bar was ran on the top of the axle to the frame above the front spring mount. The axle pivoted on the shock mounts in a fashion similar to a sliding ladder bar/leaf spring setup, without the sliding.
klesteb@aol.com
Author:  kesteb [ Wed Oct 16, 2002 2:53 pm ]
Post subject:  Re: wheel hop during shifts
Here is a link to the Shelby Mustang traction bars:
http://www.mustangsteve.com/underrides.html
It is similar to what Andrew tried to do.
klesteb@aol.com
Page 2 of 2 All times are UTC-08:00
