My 82 D-150
https://mail.slantsix.org/forum/viewtopic.php?t=46311
Page 2 of 3
Author:  Jeb [ Wed Sep 14, 2011 6:37 am ]
Cutty say he can't hang.
Don't forget the sequel: http://www.youtube.com/watch?v=EkJc5Vc5 ... re=related
Author:  Ross [ Sun Sep 18, 2011 6:49 pm ]
Im surprised you only get 14. Mine got 18 with the leanburn once. lol but i do have s 4 spd no OD. When my leanburn computer quite i was getting about 11mpg.
Switched to hei and i got 15 with a bad running carb, ive tried 3 different holley 1920's and the only carb that has worked good on my truck is the original 1945 that had a ported spark tube. Mine also has the 2 piece intake. the 2bbl intake im making is an 85' single cast aluminum intake.
Yours must be a light half ton, because ive pulled a trailer weighing about 1.5tons and it didnt even make the back level with the front. Ive also had 500lbs of line chalk in the bed and that didnt level it either. Mine seems to pull anything.
Author:  Jeb [ Mon Sep 19, 2011 3:50 am ]
I think what Chrysler did was slap D-150 badges on this truck, even though it's actually a D-100. Then they added the D-150 price. Seriously, what heavy half ton actually comes WITHOUT a front sway bar?
500 pounds in my bed and I'm looking at the sky. They actually look like the same springs that are on that old M-body rear end I've got behind my shop.
Author:  Jeb [ Sun Oct 23, 2011 3:41 pm ]
Well, I haven't been on here in a while so I decided to check back in with everyone. My dad is recovering from his knee surgery so I've had some more time to devote to my truck.
So far this is what I've accomplished:
Completed the Lean Burn removal and HEI installation (truck runs great, starts easy even without a choke)
Removed smog pump, gutted it, repacked the rear bearing, and reinstalled it so now it's just a silent idler pulley.
Blocked off the air pump tube to keep exhaust gas from getting pushed back up into the pump (bad check valve)
Installed an auxillary trans cooler
Removed the power steering pump, rebuilt it, and reinstalled it.
Installed new power steering hose to replace the mopar originals
Replaced the original Mopar upper radiator hose
Replaced the factory 195* thermostat with a 180* unit
Blocked off the EGR valve
Removed the EGR "octopus" from the manifold
Rebuilt the carb, found a loose idle pickup tube and staked it back in place
Installed a new set of Autolite plugs gapped to .045
Installed my new electric fan and controls
Next on the list is a transmission fluid & fliter change and a much needed band adjustment.
Author:  Rob Simmons [ Mon Oct 24, 2011 6:31 am ]
Quite a bit of wrenchin' you've been doing Jeb! Way to go! :D
Author:  Jeb [ Mon Oct 24, 2011 7:39 am ]
Yeah, I would start on one thing and then find something else that needed attention. So I've pretty much worked my way around the entire engine bay in this truck.
Author:  BUCKET 636 [ Mon Oct 31, 2011 1:35 pm ]
Keep up the good work. 8)
Author:  Jeb [ Mon Oct 31, 2011 9:11 pm ]
Well, I got everything reassembled on the truck and took it for a test drive. Even with that puny 1945 it's a pretty strong runner and has gobs of low end now. Also serviced my transmission and it shifts much nicer, but it still has that annoying BANG everytime I put it into reverse.
Anywho, fast forward to yesterday. I had just finished waxing my truck and had it nice and shiny. I cranked it up and backed it out of the shop and noticed a puddle of water on the floor where I had it parked. A little investigation turned up a leaking weep hole on my water pump.
So...
I took everything back off again, removed the aftermarket A/C bracket (since it's bolted to the water pump), A/C compressor, smog pump, and the idler pulley. Then it hit me, since I already have all this crap off the truck, why not go ahead and slap the super six on it since I was going to have to remove all the stuff AGAIN to swap out the manifolds.
So, I pulled 1 barrel intake/exhaust combo off the truck tonight. Soaked everything down with PB Blaster before hand so for the first time none of the bolts wrung off. I have to admit, that aluminum intake is a lot easier on the back than that cast iron one!
So here is my engine now. I stuck my finger in the intake ports and the valves are nice and clean (thank you seafoam).
Date my engine was "born"
Author:  emsvitil [ Mon Oct 31, 2011 9:59 pm ]
Don't forget to remove the rags from the intake and exhaust ports..................
:wink:
Author:  Rob Simmons [ Tue Nov 01, 2011 5:57 am ]
Hey Jeb,
I love your attitude! :D :D
I bet you could help me figure out how to set the timing if I came to another race down at SGMP, huh?
You've come a long way, my friend! (Certainly a LOT further along than me... :wink: )
Author:  Jeb [ Fri Nov 04, 2011 9:13 am ]
Well, it's time for more updates. Things have slowed down a bunch since I'm now getting to the tedious nit picky part of things. All I've done the past two days is repaint old parts and remove old gasket material.
My repainted super six manifold
Touched up exhaust manifold. It's painted with POR-15 manifold paint, which seems to work very well.
Author:  Reed [ Fri Nov 04, 2011 9:42 am ]
Author:  Jeb [ Sun Nov 06, 2011 5:11 am ]
Stuck the manifolds together this morning for a photo op. Ordered a Remflex gasket set last night since I only want to do this once. The first time it's an adventure, the second time it's just annoying.
Author:  Jeb [ Mon Nov 14, 2011 4:34 pm ]
Finally, after what seemed like an eternity, my remflex gaskets arrived. Got the manifolds on and finger tight. I plan on torquing everything down tomorrow and hopefully starting the truck.
Also managed to find a NOS temperature gauge, so I now have a full compliment of gauges. I've already changed the sending units for gauges from the idiot light senders. I just hope everything works.
All that's left now is to install my new water pump, A/C bracketry, bleed the brakes, and replace the vacuum lines for the brake booster and the cruise control.
Author:  Jeb [ Tue Nov 15, 2011 4:47 pm ]
IT LIVES!
Fired up the slant today and I'm glad to report that I have no vacuum leaks. I didn't have the head pipe bolted up so I just let it run for a few seconds to make sure it would idle and that my mixture screws would work.
The only problem I have now is an annoying fuel leak on the front of the carb where the line goes in. Did they change the flare on the fittings in the 80's, because I didn't have this problem with the Duster.
Page 2 of 3 All times are UTC-08:00
