| Slant 6 10" Performance Clutch Install 3-16-12 https://mail.slantsix.org/forum/viewtopic.php?t=48219 |
Page 2 of 14 |
| Author: | Greg Ondayko [ Sun Mar 18, 2012 3:41 pm ] |
| Post subject: | Began Transmission Removal 3-18-12 |
Nothing too excitin' Here, Starting the Trans removal process: ![]() ![]() Take pictures of the Linkages before you take them out - It will help during re-assembly. ![]() Greg |
| Author: | wvenable [ Sun Mar 18, 2012 4:54 pm ] |
Gosh dern (Censored), recover those seats. Looks like a leisure suit my dad owned! |
| Author: | sandy in BC [ Sun Mar 18, 2012 5:09 pm ] |
Disco Edition....... |
| Author: | Rug_Trucker [ Sun Mar 18, 2012 5:47 pm ] |
In Mike Meyers Scottish brogue "IF IT ISN'T SCOTTISH? IT'S CRAP!!" |
| Author: | Dart270 [ Sun Mar 18, 2012 7:33 pm ] |
Forgot about the friction insert. Bummer. It might be ok... Lou |
| Author: | Greg Ondayko [ Sun Mar 18, 2012 7:48 pm ] |
| Post subject: | Out With the Old 3-18-12 |
Quote: Gosh dern (Censored), recover those seats. Looks like a leisure suit my dad owned!
No Way wayne - I have Extras in my attic with the same fabric and I Bought out an Vintage auto upholstery warehouse - I have yards of that stuff.. Plaid On Brother!anyway back to business: I pulled the trans and old PP / Clutch / Flywheel out of the Duster. ![]() Test fit the New disc on the actual trans in will be going on.. No issues. ![]() Old Greasy Bell and other stuff will get a bath in the parts washer! ![]() ![]() Here are some shots of the Old Flywheel, 10" custom Disc that I had used and Custom 10" Borg& beck Press. Plate. The Old Disc and Press. Plate were made by a local clutch Rebulder - He has since Retired and Closed Shop ![]() This B& B Press Plate Has 12 Springs and I believe 2400# Holding force.. Good for a daily driver but it is the exploding Cast Iron Stuff ![]() ![]() ![]() The Clutch Was a stock Borg & Beck 10" with 9 kevlar Buttons on it - Those buttons used to be 1/8" tall when It was new. ![]() ![]() ![]() ![]() ![]() ![]() Pressure Plate Finger Height Comparison. Pay attention Here! This Is important for Making your Clutch Fork Pivot Shims. Stock PP: ![]() ![]() This Measurement Looks to Be Right Around 2 3/4" ![]() New McLeod PP Finger Height: ![]() This Measurement Appears To be 2 5/8" ![]() I will use this measurement to setup the the new Clutch Fork Distance - Based on my own other project with the McLeod parts, and others who have used these parts before 2006 You might have to shim the Clutch fork 1/4" to 1/2" Closer to the Engine to get correct Pedal travel & clutch rod geometry. Greg |
| Author: | vynn3 [ Mon Mar 19, 2012 9:54 am ] |
For those of us considering a 4-spd swap but who know next to NOTHING about clutches and such (unless I'm the only one here...), Best. Thread. Ever. THANKS, GREG!!!!!!!! This should definitely be a sticky... |
| Author: | Greg Ondayko [ Thu Mar 22, 2012 3:29 pm ] |
| Post subject: | 3-22-12 Flywheel Issues/ Concerns |
Well - A Moderator has Made this a Sticky! Thanks Mods! I have been pretty busy with work & other things so it's been a few days since my last update.. I have been piecing together the parts for this install and I noticed something of concern. I am trying to get an expert answer on this before I forge ahead with the project. I had particiaped in theWilcap AL flywheel Group Buy back in 2008. This is a super nice flywheel (i will do a weight comparison soon) that (if you read the old post) I was adamant about the Flywheel that I ordered having the Ford 10" pressure plate mounting holes drilled onto it. Well they are drilled on The Wilcap Flywheel and the PP i got last week from Summit/McLeod Fits fine on the Flywheel. My concern is the Steel Friction insert: ![]() As you can see the insert is only 9" in diamater and the Clutch I want to use with this package is 10" and the PP is also 10". ![]() With the Steel friction insert being only 9"..........1/2" of the clutch disc and pressure plate will overhang this steel insert.. I am not sure i that's a good thing. ![]() I am waiting to hear back from wilcap to see if the Steel insert can be replaced with a 10" piece. I have not heard yet. The other option will be to by the Steel SFI certified McLeod Flywheel Part# 464001 Since I had the Wilcap Piece in storage in my shop I wanted to use it - The Mcleod Piece will be some more ca$h that I would like to hang onto if possible. I have one of the McLeod Dual Pattern Flywheels in the Dart - no problems - I just wanted to use the AL flywheel on this project. We shall see. If you have any thoughts on this chime in. Greg |
| Author: | Joshie225 [ Thu Mar 22, 2012 7:01 pm ] |
The friction surface on the flywheel needs to match the disc. If it doesn't you're losing a lot of clutch area. |
| Author: | Dart270 [ Fri Mar 23, 2012 9:43 am ] |
Let me know if Wilcap will redo the insert. I'd want mine done that way too. Thanks again for great thread. Lou |
| Author: | Greg Ondayko [ Mon Mar 26, 2012 10:49 am ] |
| Post subject: | Wilcap 3-26-12 |
Quote: Let me know if Wilcap will redo the insert. I'd want mine done that way too. Thanks again for great thread.
I spoke with the Fine Folks@ Wilcap and The 10" insert on the Slant AL flywheel is a no-go - THe technical reason is that there would be no meat left in between the AL the Steel insert and the Ring Gear Rivets..Lou The AL flywheel will be a 9" to 9 1/2" only clutch piece - I suppose I could get a Nice 9" PP and make that combo work - But that will be on another project.. I ordered the McLeod 464001 Flywheel and Once that comes in I will continue with the Install. Greg |
| Author: | Greg Ondayko [ Mon Mar 26, 2012 8:26 pm ] |
| Post subject: | Cleaning / Shimming / Trimming 3-26-12 |
Here are the Next Step(s) in the Process: Before Re- assembly of the clutch / PP / Flywheel I like to Clean the Bell Housing inside and out before the Reinstall: Using The parts washer All the old greasy Gunk and clutch dust are removed from the stuff I am going to put back into the car: ![]() ![]() The stuff is clean Now! ![]() ![]() Even though I am not re-using the Old Flywheel on this project; I am cleaning it and Sending it to the machine shop for surfacing; I will stash it away and Possibly re-use it on another project Later ![]() For This pressure Plate Install I will have to shim the Clutch Fork Pivot Closer to the Flywheel / Engine - If you are using a stock type Pressure Plate this step is NOT Needed. ![]() ![]() I removed the Old Clutch Fork Pivot and Used it to layout some bits of Steel to make the spacer. I marked the holes and Got the general outline for the Spacers. Also the Stock Bolts That hold the Fork Pivot will be waaay to short so I will replace those too. ![]() Here are some shots of the Spacers I made - I was using some left over angle Iron and Made the spacers - No they are Not Billet, nor are they pretty but they will do the job. ![]() ![]() ![]() All 3 spacers are done; they measure about 1/2 Inch which should be just right for this setup - I can always unbolt the fork pivot and add or subtract the spacers to get it right. ![]() ![]() Next are some shots will all the spacers and Clutch fork pivot installed and bolted down.. Notice the longer bolts needed for this. ![]() ![]() ![]() ![]() ![]() All complete and A New Throwout bearing too.. I usually Toss In a New TO Bearing if I have the tranny out and I dont want to do the job again anytime soon. ![]() Now Lets take a look at that 10" Ford/Mazda Pressure Plate from McLeod. I had some trouble with the clutch hitting / binding on the bolt hole material of the Pressure Plate Hat when I did this install on the dart back in 2006 - It is much easier to cut / grind these tabs before the install raher than after. ![]() The Pen points to the Black line where I am going to make the cuts; This will happen on 6 of the mounting points. ![]() ![]() ![]() Tools I used to do this hack: ![]() Bits Removed - Not Much but enough to alleviate hassles later. ![]() Photos of the PP after Cutting the six Little tabs off: ![]() ![]() Pen Points to where the cuts were made: ![]() ![]() Next: Test fitting the PP / Clutch / Flywheel / Clutch rod etc.. I have to Wait for the McLeod 464001 Flywheel to come in to do this. Greg |
| Author: | Rick Covalt [ Thu Mar 29, 2012 5:52 pm ] |
| Post subject: | Flywheel |
Quote: I ordered the McLeod 464001 Flywheel and Once that comes in I will continue with the Install.
Greg, It would sure be nice if McLeod could get the center registry right to start with. I know it is not a huge deal, but it should not need to be taken to a machine shop out of the box. It cost us $40 and 2 days of waiting to get ours done.Maybe this one will be correct? Let us know. great write up by the way!! Rick |
| Author: | Junior [ Sat Mar 31, 2012 2:29 pm ] |
What makes the stock flywheel not a good choice for this mod? |
| Author: | Greg Ondayko [ Fri Apr 13, 2012 8:16 pm ] |
| Post subject: | Parts Update 4-13-12 |
@ Junior - Well I would not use the Stock Flywheel for 2 reasons - #1 It's made from Powdered metal - Like cast Iron I suppose.. In a performance situation Things could fly apart and this can hurt or seriously hurt someone Not to mention damage you car quite a bit.. I have been there - Not fun. #2 to use the Ford 10" PP the Bolt pattern for this on a slant Flywheel Has to be VERY close to the edge.. Near the ring Gear - The steel piece will do a better job with this small amount of material near the edge of the bolt holes.. and Not to mention you have to find a very competent machine shop to modify you stock PP to do this.. Could it be done .. yes I would not choose to do this. Update... I ordered part #McLeod 464001 This time I used a local guy in town that was cutting my old flywheel - He is a McLeod Dealer - So a few weeks go by and I get the flywheel in.. I ask him to check the Center register - 'cause If it needs machined out to 2.165" (i am installing in a '68 up application) He could do this before I picked up the part.. He verified that the part had indeed come in with the '68 Up register... Great. So I get home and notice the pP mounting patterns look funny... It came with 2Sets of Mopar Borg& Beck PP Mounting holes drilled on it. This certainly wont work.. Currently Waiting on a return to McLeod for a correction on this. I did not have this problem 6 years ago with the part in the Dart - It was right the first time with the dual PP mounting pattern. If you are interested in this flywheel maybe call McLeod Tech and Be sure to verify the 2 Patterns before they make yours. Pics: Here is the New McLeod Piece - Weighs 20# Notice the "double" stock PP mounts.. ![]() McLeod Piece Came in with the large Register: ![]() Stock Flywheel Has been Cut a few Times - Weighs In @ ~17# ![]() The Ford 10" PP does not line up anywhere on this McLeod Unit - It should - They screwed up:-( ![]() Shots of the Stock PP lining up on 2 Sets of Holes. - Dumb ![]() ![]() ![]() ![]() ![]() More to come when info is Available. Greg |
| Page 2 of 14 | All times are UTC-08:00 |
