| High compression build with cast pistons? https://mail.slantsix.org/forum/viewtopic.php?t=50846 |
Page 2 of 2 |
| Author: | 66aCUDA [ Sat Jan 19, 2013 3:47 pm ] |
Use what ever you want. It all works good. Frank |
| Author: | slantzilla [ Sun Jan 20, 2013 8:51 am ] |
IF you keep it out of detonation cast pistons will live forever. Detonate it very much and even forged pistons will not last. |
| Author: | Dart270 [ Sun Jan 20, 2013 12:47 pm ] |
My understanding is that forged pistons are reallly for strength at high revs (over cast), but forged are not drastically stronger than cast when overheating them with detonation. Lou |
| Author: | Sprag [ Sun Jan 20, 2013 8:05 pm ] |
Thanks again for the advice, it really helps and now I think I've done it right so far Stage Two planning is underway - Offy 4 bbl intake has arrived, header dreams run rampant and the separate budget for the E85 carb is in the works. |
| Author: | NCDemon1971 [ Sun Jun 23, 2013 9:27 pm ] |
| Post subject: | Re: If stock... |
Quote: So far my 1980's engines have had a stock deck heght in the .175-.190 range making it hard to make a 'guess' without actual measurements. The peanut plug head has seen a range of about 56-52 cc at the chamber after taken off the engine without modification...the 1976-1978 head are a bit tighter in the 53-54 cc range stock...
I have noticed this to. My previous bracket car ('71 Duster) was a 1974 steel crank engine with a later style peanut plug head. I recently had a tube style head from a 198 milled over .100 and when compared to the peanut plug head, it shocked me at how close the chambers looked. The peanut plug head was stock/untouched. To get 12:1 out of a 1963 block and 1978 head I ended up cutting .120 off the block and about .100 out of the head....(you will need ARP head studs after this...) FYI, -D.Idiot Maybe I should have done the peanut plug style head. I already had hours of port work into the 198 head though and if you are weight freak like me, the tube heads are a tad bit lighter. Good info, D.Idiot! |
| Page 2 of 2 | All times are UTC-08:00 |
