| Any Interest in a Turbo Header? https://mail.slantsix.org/forum/viewtopic.php?t=52496 |
Page 2 of 2 |
| Author: | Turbo Toad [ Sun Jun 30, 2013 6:12 pm ] |
Also my 62 valiant was a power steering car. I have a bunch of pics of the engine bay with my original turbo manifold? But if you put the turbo in or around the battery box it will discharge oil well and fit just about any application minus AC Aaron |
| Author: | Rug_Trucker [ Sun Jun 30, 2013 6:29 pm ] |
I like it! I just worry that a Fram oil filter could kill the engine collapsing like they have been known to do. |
| Author: | billdedman [ Sun Jun 30, 2013 7:00 pm ] |
| Post subject: | Filter, schmilter... |
So, if you're that paranoid about it, run a different one... no problemo.... |
| Author: | Rug_Trucker [ Mon Jul 01, 2013 6:53 am ] |
| Post subject: | Re: Filter, schmilter... |
Quote: So, if you're that paranoid about it, run a different one... no problemo....
I do! Brand new rebuild on my van I could only get 20lbs of pressure with a HV Melling pump, and the rods rattled on start up. Changed to a Pure and problem was fixed. Step daughter's Lumina had one collapse and kick a rod.
| Author: | billdedman [ Mon Jul 01, 2013 9:56 am ] |
Quote: Quote: So, if you're that paranoid about it, run a different one... no problemo....
I do! Brand new rebuild on my van I could only get 20lbs of pressure with a HV Melling pump, and the rods rattled on start up. Changed to a Pure and problem was fixed. Step daughter's Lumina had one collapse and kick a rod.I, personally, have used FRAM filters on all my vehicles since I started driving in 1955, and have never had a problem of any kind... So, I can see your pont, but you can see mine as well... |
| Author: | billdedman [ Mon Jul 01, 2013 9:57 am ] |
Quote: Quote: Quote: So, if you're that paranoid about it, run a different one... no problemo....
I do! Brand new rebuild on my van I could only get 20lbs of pressure with a HV Melling pump, and the rods rattled on start up. Changed to a Pure and problem was fixed. Step daughter's Lumina had one collapse and kick a rod.I, personally, have used FRAM filters on all my vehicles since I started driving in 1955, and have never had a problem of any kind... So, I can see your point, but you can see mine as well... |
| Page 2 of 2 | All times are UTC-08:00 |
