Drag racing pan mods
https://mail.slantsix.org/forum/viewtopic.php?t=60637
Page 2 of 2
Author:  Greg Ondayko [ Fri Jan 20, 2017 3:36 pm ]
Studs with loctite..
Also drill the bolts and run saftey wire..
I use loctite red on factory bolts too.
Author:  Rick Covalt [ Sat Jan 21, 2017 5:22 am ]
With most of those holes being through holes, what keeps the studs tight? Just the lock tight?
Thanks
Author:  Greg Ondayko [ Sat Jan 21, 2017 7:12 am ]
A Clean application of Loctite red 271 to clean dry threads will do it.
You may not need studs on every hole as this may hinder oil pan install, but definitely them it on the side with the crank scraper.
Also clean application of red loctite on the Factory type studs will work well too!
Author:  Will [ Sat Jan 21, 2017 6:30 pm ]
Studs with nylock nuts. Some of the studs have to be put in after pan is installed.
Author:  Rick Covalt [ Sat Jan 21, 2017 6:37 pm ]
Post subject:  Link to answers
I knew I had asked that question before, but my search function on here is not very good! Thanks again.
http://www.slantsix.org/forum/viewtopic ... e810d87319
Page 2 of 2 All times are UTC-08:00
