Whats everyone got for wheels?
https://mail.slantsix.org/forum/viewtopic.php?t=6293
Page 2 of 3
Author:  Pierre [ Sun Jul 20, 2003 2:29 pm ]
Lots of foriegn cars use 100mm x 5 bolt patern. 4" would be 101.6mm, slightly bigger, but the slack is easily taken up by the lugnuts. When you tighten them down the wheel will be centerd anyway. It's not like stock wheels fit perfectly over the studs anyway they also have some play, so adding 0.8mm play to each hole isn't a big deal.
Author:  Guest [ Mon Aug 04, 2003 10:57 am ]
I run 17 inch Fikse rims. I needed the 17 inch rims in order to clear the 13 inch Viper disc brakes.
Author:  andyf [ Mon Aug 04, 2003 11:05 am ]
Whoops, guess I forgot to log in before posting! The '65 Coronet is mine. It doesn't have a /6 in it but I figured people might be interested in the wheels and tires anyway. It has drum brake knuckles from a '73 A body and custom machined hubs to hold the Viper rotors. That setup will fit on any A body car if the appropriate upper ball joint is used.
Author:  moose340 [ Mon Aug 04, 2003 8:02 pm ]
Post subject:  Rims..
Centerline autodrags- 15 x 7 all around with Radial t/a's. p215/65r15 and p235/70r15 on rear. Centerline rims were custom made took 6 weeks to get.
Author:  Bruce Johnson [ Mon Aug 04, 2003 9:42 pm ]
For truckers only, Sorry car owners, 10" by 15" steel rims with Indy centers welded at 4 3/4" backset, 295 50 radial tires. Due to reworking my rear wheel tubs I have room for 14"by15" rims but for now I'm rotating a set of five wheels painted with yellow Imron. P. S. having seen Bret's car in person I was Impressed with the fit of the chosen wheel/tire combo with those new disk brakes. I would Think pearl white or metalic silver and get over it. Bruce J.
Author:  greasy 225 [ Tue Aug 05, 2003 1:49 am ]
I just wish I had 14"s on my car, nice black stock steelies with chrome lugnuts. On my '62 Valiant the rear wheel openings are really tall and need to be filled with a taller wheel/tire.
-Jesse
Author:  slanted attitude [ Wed Aug 06, 2003 4:51 pm ]
On my 60 valiant ,Im running 16x8 firebird wheels by using billet adapters from Stocton wheelworks and they fit well and look good.
Author:  Dart270 [ Wed Aug 06, 2003 8:45 pm ]
Hey Slanted attitude,
How about some pics of your Valiant? Sounds like a cool wheel setup.
Author:  Middy [ Thu Aug 07, 2003 7:38 am ]
Nice Rims all!
I've been looking for some Torq Thrusts I's too I figured to use the 16 x 8's on my 340 car but I'm not sure how the Dart's rear wheel house is going to like the 5" backspace I may have to get a spacer to get it to around 4.5 BS will see when I finally save up enough dough to buy em. don't go too big on the rims I find alot of newer style rims with lots of airspace and tiny spokes look insubstantial on an older car.
Most important get some rims YOU like cause that's the only guy that has to like em.
Author:  Dennis Weaver [ Thu Aug 07, 2003 7:46 am ]
:!: True, but it's also nice to look cool when you make the scene in your cherry Mopar with some bitchen' wheels.......
"DW"
Author:  Dart270 [ Thu Aug 07, 2003 11:35 am ]
Middy,
You should definitely make measurements, but I would bet that 5" backspace will be about perfect with stock drums and big bolt pattern - might even want 5.25"...
Author:  Doc [ Thu Aug 07, 2003 12:53 pm ]
I have always liked the chrome "reversed" rim with some factory stainless steel "dog dish" hub caps. :D
<img src="http://www.dutra.org/doug/dougs-darts/gconvert.jpg"width=400>
Author:  kesteb [ Thu Aug 07, 2003 1:23 pm ]
I am using stock OEM steel rims, 15x5.5" on the front, 15x7" on the rear, painted semi-gloss black with dog dishes. Looks great with rustloem red primer.
Author:  73ScampSSS [ Thu Aug 07, 2003 1:39 pm ]
Post subject:  Dart wheels
Stock baby! Big bolt pattern. (with 12" discs hidden behind)
Ive always liked the Torq Thrusts though. Im considering either 17x8 or 16x8 of the Torq Thrust IIs, they are the all chrome new design. Would 17x8s fit on my Scamp?
Author:  73ScampSSS [ Thu Aug 07, 2003 1:40 pm ]
Post subject:  pictures on site
How do I post a pic of my Scamp with the message?
(see this link in the "How to use the Message Board" section)
http://slantsix.org/forum/viewtopic.php?p=17805#17805
Page 2 of 3 All times are UTC-08:00
