| Rebuilt transmission https://mail.slantsix.org/forum/viewtopic.php?t=64586 |
Page 2 of 2 |
| Author: | SlantSixDan [ Tue Mar 10, 2020 12:49 pm ] |
| Post subject: | Re: Rebuilt transmission |
That $750 rebuild is going to be much more appropriate. You don't need to be thinking about special stall speeds. Get a stock rebuilt torque converter; that's what's suitable for the kind of car you're building. 3000 RPM is much, much too high; that would be a race car piece, and you'd be pissing away gasoline money every time you drive the car, and heating up the trans fluid to the detriment of everything, and it'd be a poor match for the low-RPM torque motor you'll want in a fun-driving car like you're building. Attached to this post is the factory '69 stall speed chart. Your situation is the 2nd line in the chart: 225 engine and 904 transmission. More/higher is not necessarily better! And be very picky and specific with the shop about that "mild shift kit". Specify a Transgo TF-SC. You could go one step further to a TF-1, but there wouldn't really be a benefit and you might not like it so much. There really isn't a whole lot of re-engineering or upgrading needed here; you're starting with a very well engineered transmission. Attachment:
| Author: | Montana A Body [ Tue Mar 10, 2020 8:26 pm ] |
This one https://www.ebay.com/i/191920797415?chn ... aAhVeEALw_ Thanks for all your help. |
| Author: | SlantSixDan [ Tue Mar 10, 2020 8:58 pm ] |
Yup! That one. |
| Author: | volaredon [ Fri Mar 13, 2020 7:41 pm ] |
Save the money, do like Reed said and also like I do, rebuild your own. I'm about to do just that on the A500(42re) in my daily driver 99 Dakota to fix it's slipping 2nd gear. Just waiting for 1 more part to arrive in the mail before I pull it. |
| Author: | captproblem [ Sat Mar 14, 2020 5:16 pm ] |
I would add that care not tearing lip seals and cleanliness are two major reasons for transmission rebuild failures. Patience and cleanliness are all you need for a successful rebuild. |
| Page 2 of 2 | All times are UTC-08:00 |
