| Hypothetical Cam Question https://mail.slantsix.org/forum/viewtopic.php?t=65523 |
Page 2 of 2 |
| Author: | Dart270 [ Fri Nov 20, 2020 12:21 am ] |
| Post subject: | Re: Hypothetical Cam Question |
I have never had a perf cam set up at less than 0.015" int and 0.022" exh lash. IIRC, that OCG 346 runs best (hot idle stability and vacuum close to that of near-cold numbers) at around 0.020" int and 0.026" exh. I wish I had more data/ideas about ramp and adv dur for you, but I don't... Lou |
| Author: | justa170 [ Fri Nov 20, 2020 2:54 pm ] |
Quote: If you think your Offy 2x1 intake will be the choke point for your build, have you considered modifying it for a 2x2 setup? Quote: I have seen guys put a pair of BBDs on that intake too. You guys are a terrible influence in the best possible way. I ordered COMP Cams 901-16 springs and 744-12 retainers. Question: Is "#346 with 110-degree LSA," all the information OCG will need? |
| Author: | Dart270 [ Sat Nov 21, 2020 3:23 am ] |
Ask OCG to grind with a 110 LSA and, if possible, can they grind it with 104 intake centerline. 106 CL would also work well I'm sure. Best, Lou |
| Page 2 of 2 | All times are UTC-08:00 |
