Help with carb d150 not starting
https://mail.slantsix.org/forum/viewtopic.php?t=66085
Page 2 of 2
Author:  Slantsix83 [ Thu Jul 15, 2021 1:30 pm ]
Post subject:  Re: Help with carb d150 not starting
Too much air? Do you mean a vacuum leak?
It sounds like you need to adjust your choke, adjust your idle mixture, and check for vacuum leaks. It also sounds like you need to get a factory service manual for your vehicle and get the books listed in this thread: CLICK ME
What should I focus on first choke idle air?
Author:  Reed [ Thu Jul 15, 2021 2:09 pm ]
All of it. Step one is to make sure all the settings on the carb are correct. If the choke and float level are correct, then start the engine and let it warm up. Once it is warmed up, check you idle speed, your idle mixture, and check for leaks. You have to do those last three all at once because they all affect each other.
Author:  Slantsix83 [ Sat Jul 17, 2021 9:43 am ]
I was able to get it running. Not perfect but ill keep adjusting. Thanks to everyone that helped
Page 2 of 2 All times are UTC-08:00
