| From naturally aspirated 225 to a boosted 170 https://mail.slantsix.org/forum/viewtopic.php?t=66100 |
Page 2 of 3 |
| Author: | Dart270 [ Wed Aug 07, 2024 11:10 am ] |
| Post subject: | Re: From naturally aspirated 225 to a boosted 170 |
It takes seemingly forever for me to get results sometimes, but I always get results eventually! FYI, I will be attending a science conference in Tromso, Norway in 3 weeks, and I almost got a flight with a stop in Helsinki. I also thought about trying to get a 1-3 day stop in Finland, but I was not able to do that. Someday, it would be great to meet you! Anyway, just letting you know I was thinking about that. Cheers, Lou |
| Author: | lgu32 [ Wed Aug 07, 2024 12:29 pm ] |
You’re welcome when you have possibitity to come here. Pls inform before to confirm I am here; We just finished one week mc tour where we ride Stockholm-Oslo-Stavanger-Bergen-Oslo-Stockholm loop. |
| Author: | Dart270 [ Wed Aug 07, 2024 2:51 pm ] |
Will do! No idea when this might come up again. Wow, that sounds like a great cycle trip! Lou |
| Author: | lgu32 [ Tue Aug 27, 2024 5:34 am ] |
That should get you down at least 500 RPM and it should still be great up high. I would even go 216 LSA and maybe 214 deg @ 0.050" for a street car, or 218/218 and 116 LSA sounds about perfect. Leighton Drake used quite small cams (like the MP 244/0.436" cam) and still made 500 HP on a 225. I am going to try the Howards cam 214/214 with 0.450" lift and 112 or 114 LSA on a 225. On a 170 you should go wider on the LSA. Kenny Duttweiler (famous turbo V6 guy and Bonneville authority) recommended 116 LSA for Bob Dally's 170 bcuda with turbo.
Such a 218/218/116 cam now exist. I probably install it to somewhere 112 to 114. Lou I bought a used core cam with an oil pump it has been driving. If the pump looks okay I will use it. If not I will use the gear to the new pump. I dont need 6 bolt pump as I have a oil sprayer in the location of distributor. Ignition is made by waste spark six output coil. |
| Author: | Dart270 [ Wed Aug 28, 2024 11:48 am ] |
Cool! Good luck with the building and testing... Lou |
| Author: | lgu32 [ Wed Oct 23, 2024 9:37 am ] |
As my garage season is just opened - I got other stuff out of it and autumn is going too cold for my E85 Dart - I am planning go and start the build. My head is "blueprinted" to 58cc and the block has almost stock height - letters stamped from factory still exists. Pistons are "some brand" and just below the deck. As I dont plan to run gasoline ever with this but just E85 should I mill the head a bit for compression increase? Something like 9-9.5. Still the 218-218-116 cam is pretty much wilder than stock. |
| Author: | Dart270 [ Wed Oct 23, 2024 2:46 pm ] |
I am not schooled in E85 usage. Maybe search internet for how much CR you might increase vs. gasoline on boost? I would probably stay at 8.5-9:1 myself, but again I have not researched this... Lou |
| Author: | lgu32 [ Wed Oct 23, 2024 11:52 pm ] |
It is said "not pinging". The rattle heard is because parts are bending and cracking. Probably I keep what I have and just control the boost by ECU. Lou I am planned to set the cam to about same as the 224/224/110 was. Intake in between 106-110. So the biggest difference with the new cam is the exhaust lobe advance by the added LSA (116-110=6). And I hope the factory cam core with factory pump gear will be better than parts I have had. |
| Author: | lgu32 [ Mon Feb 24, 2025 2:49 am ] |
First start with a new cam. As I have efi I found huge lambda value change at low vacuum. The map was build to make 1.0 at low vacuum but with a new cam I saw 1.3 or more. This mean that the engine get some 30% better fill at low vacuum with the new cam. As we still have winter I cannot do remapping or roadtests yet. But what I did at the garage using brake I found boost at stall. Seem I have got good suggestions from you guys. New cam is 218 @ 0,05” with 114 LSA. Old was 224 @ 0,05” and 110 LSA. |
| Author: | Dart270 [ Mon Feb 24, 2025 5:00 am ] |
That's great! You may not lose much (or anything) at higher RPMs, and building the boost down low will really help with ease/predictabtility of driving, and getting you off the line more quickly. I'm excited to hear about tests... Best wishes, Lou |
| Author: | Dart270 [ Sat Mar 08, 2025 3:12 am ] |
Yes, looks promising. Must be only a tiny throttle opening. I have never looked/tried a MAP sensor upstream of the throttle, and that is a great idea. What type/brand/size turbo do you have on there again? Lou |
| Author: | Dart270 [ Sun Mar 09, 2025 3:03 am ] |
Sounds cool. Interested to hear about road tests when you have good weather, etc. Lou |
| Page 2 of 3 | All times are UTC-08:00 |
