| Anybody building or built one of Doug D's big 170 slants? https://mail.slantsix.org/forum/viewtopic.php?t=66761 |
Page 2 of 2 |
| Author: | Greg Ondayko [ Thu Sep 15, 2022 8:45 am ] |
| Post subject: | Re: Anybody building or built one of Doug D's big 170 slants? |
Does it rev less / like to rev less with a 198 crank vs the 170 crank? Greg |
| Author: | Dart270 [ Thu Sep 15, 2022 12:47 pm ] |
Well, more power per cylinder for 198 crank might give higher revving, but shorter stroke for 170 crank and larger head flow per cylinder might favor higher revving. Also, the shorter the stroke, the less load on rods, pistons, and bearings at a given RPM. I see no reason you could not rev 7000 with either crank given that a 225 will rev 6000 reliably. Valvetrain might be another issue... Lou |
| Author: | Rick Covalt [ Thu Sep 15, 2022 4:23 pm ] |
The question is even if the 210 will turn 7000 rpm will the head support that amount of air? |
| Author: | Greg Ondayko [ Thu Sep 15, 2022 5:40 pm ] |
Less cubes ....does it require less runner cfm? I thinks we will find out. I bet if you get a skookum 1.75- 1.8/ 1.50 valve head with good work done to it, it could. |
| Author: | Dart270 [ Thu Sep 15, 2022 6:12 pm ] |
Yes, fewer cubes will require less head CFM at a given RPM. Lou |
| Author: | Charrlie_S [ Thu Sep 15, 2022 6:35 pm ] |
And if you need more oxygen, there is always this, "N2O". The 170 engine that was in my Cuda went 7,000 rpm a few times. But I would suggest using a low mount DS alternator. That long belt with a pass side alt, doesn't like staying on at that rpm. |
| Author: | slantzilla [ Thu Sep 15, 2022 10:17 pm ] |
The 225 in my car goes 7000 in the water regularly. I used to shift on track at 7000, but it makes no power over 6300. |
| Author: | Greg Ondayko [ Fri Sep 16, 2022 4:07 am ] |
Quote: The 225 in my car goes 7000 in the water regularly. I used to shift on track at 7000, but it makes no power over 6300.
That is a Jeffery built engine and Head correct? It's probably the exception rather than the rule. |
| Author: | slantzilla [ Fri Sep 16, 2022 6:47 am ] |
Mike gives me hell every time I tell him that. Personally I try to stay away from even less cubes than a 225. When you're already handicapping yourself with a small motor why make it worse with less power band? |
| Author: | Greg Ondayko [ Fri Sep 16, 2022 9:11 am ] |
I bet that narrow power band is fun on the street when built properly. For all out drag racing.... then booost or bottles may be needed. it's all relative. Greg |
| Author: | Doctor Dodge [ Sun Sep 18, 2022 3:32 pm ] |
Quote: About 20 lbs less weight (block) and smaller/lower profile engine. Not big deals, but why not? Why would anyone build a 170 instead of a 225?
I built a couple of "low block" 210 Slants mostly just to see if it could be done and how they worked...Lou And they "work" like a bored-out 198, less a little weight. As already noted, no big power gain or magic out of this combo but if I were to stick a SL6 into a little sports car, with a low hood line, I would likely use a low block 210. Truth is, many of the experimental hybrid SL6 engines I built over the years were done to satisfy my curiosity and "because I can" attitude... instead of trying to make the most horsepower out of an SL6. DD |
| Page 2 of 2 | All times are UTC-08:00 |
