Head Flow Infomation Wanted
https://mail.slantsix.org/forum/viewtopic.php?t=67075
Page 2 of 5
Author:  DadTruck [ Wed Feb 08, 2023 12:10 pm ]
Post subject:  Re: Head Flow Infomation Wanted
Rick, I flowed a slant head for Volaredon that had IIRC 318 valves and garage porting, I don’t remember what seats he had in it. It had decent numbers. Maybe Don will see this and post the info.
Author:  Rick Covalt [ Wed Feb 08, 2023 1:56 pm ]
The Engine builder valves are 1.7 & 1.4 or 1.44. I have that set up on my "back up" race engine that I installed in my truck. I spent @ 12-15 hours on the porting if I remember correctly. But I always wished I had it flowed. However it is not likely I would pull it just to test it.
Author:  volaredon [ Wed Feb 08, 2023 3:08 pm ]
I have that info at home , I'm not there right now.
No 318 valves, just 318 springs. I have the SI oversized valves. Same 1.70/1.44 sizes you referenced.
Author:  Rick Covalt [ Wed Feb 08, 2023 3:10 pm ]
That would be great info! Thanks
Author:  Rick Covalt [ Wed Feb 08, 2023 5:52 pm ]
200 CFM is very good, and should be good for around 300HP
If HP calculators are anywhere near correct, Ryan's 11.00 runs produce @ 324 HP by ET, and @ 308 by mph.
Author:  hyper_pak [ Thu Feb 09, 2023 8:07 am ]
I contacted the flow bench guy here and he is ready to look at my head, the one off the engine, not the other one.
$50 bucks to do 1 intake and 1 exhaust.
I have no idea if that is the going rate, but sounded reasonable to me.
I will let you know what he finds.
Author:  Greg Ondayko [ Thu Feb 09, 2023 8:12 am ]
Not sure of the going rate, but it sounds reasonable to me as well!
Now the real question... if it flows poorly how do you know what to do?
I suppose you could mess a head up real good by taking too much material off or off in the wrong place.
Author:  hyper_pak [ Thu Feb 09, 2023 8:29 am ]
Yes, the age old question.
I will listen to his recommendations and take it from there.
This head was a last minute build after I had those 2 other heads with problems.
So I was not too concerned about peak performance.
I have another here that I will be installing with bronze walls and thin stem valves.
I plan to just do minimal porting in all the recommended areas, nothing overly excessive.
Author:  Rick Covalt [ Thu Feb 09, 2023 8:56 am ]
$50 is plenty cheap! I think I paid $80 4 or 5 years ago. I think all 3 of our heads were tested on #3 cylinder. I have no idea why? I just know Mike did # 3 and had the others done on the same cylinder. :D
Author:  slantzilla [ Thu Feb 09, 2023 9:25 am ]
Just a guess, but 3 or 4 would be the easiest to get the head mounted on the bench. :shock:
Author:  Rick Covalt [ Thu Feb 09, 2023 10:08 am ]
That makes sense
Author:  CNC-Dude [ Thu Feb 09, 2023 11:09 am ]
Yes, trying mount it on #1, especially with a heavy Slant head would turn the flow bench over...! LOL
Author:  hyper_pak [ Sat Feb 18, 2023 8:57 am ]
I finished the engine on my son's Honda last week so now back on the Colt.
I dropped the head off at the flow bench yesterday.
He was not too impressed with my 318 valves and the guides in the head.
Neither am I but that was not the reason for dropping it off with him!
I was surrounded by about a million aluminum heads in his shop.
I guess it's easy to make horsepower when summit-edelbrock-trick flow-etc drop race ready parts off at your door.
Details to follow.
Author:  DadTruck [ Sat Feb 18, 2023 11:24 am ]
linking this post per Stan's request
https://www.slantsix.org/forum/viewtopi ... of+secrets
Author:  slantzilla [ Sat Feb 18, 2023 2:00 pm ]
Stan, actually he's busy because those shiny aloominum heads are not race ready when delivered. :mrgreen:
Page 2 of 5 All times are UTC-08:00
