| 1962 Valiant Station Wagon https://mail.slantsix.org/forum/viewtopic.php?t=67103 |
Page 2 of 14 |
| Author: | Greg Ondayko [ Sat Oct 28, 2023 7:30 am ] |
| Post subject: | Re: 1962 Valiant Station Wagon |
This ![]() used to be in there. ![]() Now it's not! |
| Author: | Charrlie_S [ Mon Nov 06, 2023 11:03 am ] |
| Post subject: | Re: 11/6/23 |
I have seen many slants marked like that. Not uncommon
| Author: | SlantSixDan [ Mon Nov 06, 2023 11:43 am ] |
The Head Rail Pad near the alternator may be missing a "5" after the 22? Only the first two digits of the engine displacement were stamped on the US-built engines through '64 (V-series). Starting in '65 (A-series), the whole displacement was stamped.
| Author: | Greg Ondayko [ Mon Nov 06, 2023 12:26 pm ] |
Quote: Quote:
The Head Rail Pad near the alternator may be missing a "5" after the 22? Only the first two digits of the engine displacement were stamped on the US-built engines through '64 (V-series). Starting in '65 (A-series), the whole displacement was stamped.Thank you, Dan and Charrlie! That makes sense. I never knew that, as I never had pulled an original pre-65 block out of a vehicle or inspected the numbers on one. I take back my snarky factory break comment then. Greg |
| Author: | volaredon [ Sun Nov 19, 2023 5:53 pm ] |
Any particular reason to go straight to 60-over? I've never had any engine I have ever worked on taken that far oversized. Is it already bored over? |
| Author: | Rick Covalt [ Mon Nov 20, 2023 3:28 am ] |
Better room for oversized valve to work right. |
| Author: | Greg Ondayko [ Mon Nov 20, 2023 4:19 am ] |
Yes, Rick Has got it figured out, I will be putting a head with good valves on it and retiring the stock head to be reused as a core for valve work. I had the 0.060" pistons in stock on the shelf too. I mean if it's going to the machine shop anyway for boring, why not just skip the 0.030"? It costs the same and I do not expect to have to bore the block again in my lifetime, who knows if there will even be parts available when I am real old, except for what I have on the shelf. I might just have to buy all of Charrlie's stock someday! |
| Author: | Charrlie_S [ Mon Nov 20, 2023 4:30 am ] |
Quote: I might just have to buy all of Charrlie's stock someday! |
| Author: | Greg Ondayko [ Tue Nov 21, 2023 5:07 am ] |
I would love to, but work, family, and other things in the way of an epic slant parts grab right now. |
| Page 2 of 14 | All times are UTC-08:00 |
