| Carburetor/Intake recommendations for my rebuilt engine https://mail.slantsix.org/forum/viewtopic.php?t=67188 |
Page 2 of 2 |
| Author: | cmann [ Wed Apr 12, 2023 12:47 pm ] |
| Post subject: | Re: Carburetor/Intake recommendations for my rebuilt engine |
Ok, bad news - After I adjusted the valves and let it run in the garage yesterday I decided to take is for a quick test drive to go get some gas (91 octane). By the time I got down to the gas station it started running rough again and wanted to die. I did try opening the idle mixtures and that did not help any. Again, under power it is smooth with no pause or hesitation. So, I am thinking again that maybe the throttle body has some debris in it. I am thinking of pulling the carb back off and sonic cleaning the throttle body to get any debris/deposits that are in there out. I am also going to re-time it and try to get it down from the 12 degrees it is at right now. |
| Author: | Jase [ Thu Apr 13, 2023 6:34 am ] |
Quote: Ok, bad news - So, I am thinking again that maybe the throttle body has some debris in it. I am thinking of pulling the carb back off and sonic cleaning the throttle body to get any debris/deposits that are in there out.
I am also going to re-time it and try to get it down from the 12 degrees it is at right now. If the carb had debris in the passages then I would doubt that it would run smoothly when cold. It sounds like this issue is now showing up once the engine has warmed up. Is that correct? |
| Author: | cmann [ Thu Apr 13, 2023 6:42 am ] |
Yes, that is correct. Once it is at running temperature is when it wants to start to die when idling. Again, past idle it runs great. |
| Author: | drgonzo [ Thu Apr 13, 2023 9:33 am ] |
My son's D100 did the same thing. Debris in the idle circuit. |
| Author: | Dart270 [ Thu Apr 13, 2023 11:54 am ] |
Pull idle mix screws and blow out with carb cleaner? Lou |
| Author: | SlantSixDan [ Thu Apr 13, 2023 3:03 pm ] |
Quote: a quick test drive to go get some gas (91 octane) Why are you buying high-test gasoline for this car? From what you've described of the build, it shouldn't be necessary. And if it's not necessary, it's not beneficial—just a waste of dollars. If you have to run 91 or else the engine pings…take out the excessive base timing; get it back around 5° and that should resolve the pinging.Sounds like there is (still) trash in your carb's idle circuit and/or air bleeds. |
| Author: | SlantSixDan [ Thu Apr 13, 2023 3:05 pm ] |
Quote: If the carb had debris in the passages then I would doubt that it would run smoothly when cold. If the carb has trash in the idle circuit, you often won't see a symptom until the engine is warm enough for the choke to come off and the fast-idle cam to swing out of the way.
| Author: | cmann [ Thu Apr 13, 2023 7:29 pm ] |
Thank you Dan for your reply/input. Yes, I plan on taking the throttle body off and cleaning. The engine is not pinging. I plan on bringing the timing down. Just thought I would run some good gas in it while tuning. I will keep you posted on the progress/response after cleaning the throttle body. |
| Author: | SlantSixDan [ Thu Apr 13, 2023 11:57 pm ] |
Quote: I plan on taking the throttle body off and cleaning. Good, but that might not be where the trash is located.Quote: The engine is not pinging. Just thought I would run some good gas in it while tuning It is a complete mistake to think higher-octane gasoline is better. It is not. Tune the car on the kind of gasoline you'll usually be running in it.
| Page 2 of 2 | All times are UTC-08:00 |
