BBD carb knowledge needed
https://mail.slantsix.org/forum/viewtopic.php?t=67294
Page 2 of 2
Author:  matv91 [ Fri Jun 16, 2023 4:19 pm ]
Post subject:  Re: BBD carb knowledge needed
Author:  matv91 [ Fri Jun 16, 2023 4:25 pm ]
Blue line plastic pump arm can wear or have hair line cracks. Green line wear pattern on steel s pin wear pattern. The s pin mloves in and out of pump shaft with up and down. movement. Check for burrs or smooth with file
Author:  tattoosteve99 [ Fri Jun 16, 2023 9:21 pm ]
Is there any place to get these plastic parts?
Author:  matv91 [ Fri Jun 16, 2023 11:05 pm ]
https://quadrajetparts.com/linkage-c-299_302_330.html
Author:  matv91 [ Fri Jun 16, 2023 11:07 pm ]
Looks like there out of service. Try walker next
Author:  matv91 [ Fri Jun 16, 2023 11:37 pm ]
https://www.ebay.com/itm/120345764441?h ... R5LYyYCZYg not the right one ,there were long and short yours is different. Thats carter number 111-120, you need carter 111-165 pump arm
Author:  matv91 [ Sat Jun 17, 2023 6:54 am ]
https://www.carburetion.com/Products/Pr ... t=BBD-HV32 This looks right
Author:  tattoosteve99 [ Tue Jun 20, 2023 12:28 pm ]
Thanks so much! That site also has the other piece as well. Can you tell me if it’s the correct one as well?
https://www.carburetion.com/Products/Pr ... art=85-182
Author:  matv91 [ Tue Jun 20, 2023 4:53 pm ]
That looks good to me , walker number here better picture https://www.ebay.com/itm/120345763180?e ... R-jQuq2bYg carter number 111-118 for v8 but will work in slant models just a little more mid throttle lift of metering rod,good with todays fuel.
Author:  matv91 [ Tue Jun 20, 2023 5:09 pm ]
slantsix bbd most of time got this one,not as much metering rod lift at mid throttle, after market only services v8 model https://www.ebay.com/itm/403598194643?e ... R6TgoLSbYg
Author:  matv91 [ Tue Jun 20, 2023 5:23 pm ]
factory slant six green one https://www.ebay.com/itm/334859698709?_ ... %3A2047675
Author:  matv91 [ Tue Jun 20, 2023 5:33 pm ]
After market also came in black v8 type 111-118.https://www.ebay.com/p/2098143223
Page 2 of 2 All times are UTC-08:00
