| Erratic timing https://mail.slantsix.org/forum/viewtopic.php?t=67499 |
Page 2 of 2 |
| Author: | volaredon [ Tue Nov 14, 2023 2:43 pm ] |
| Post subject: | Re: Erratic timing |
It's entirely possible that someone somewhere along the way swapped carburetors out on your engine. But the stock 1bbl for the year of the truck would have been a holley. and again for the year of the truck it was possible for it to have come with a Carter carb, but for that year the only Carter that Dodge used was a 2 bbl. |
| Author: | GTS225 [ Tue Nov 14, 2023 5:33 pm ] |
Quote: I cannot seem to upload pictures of the carburetor it has one Venturi and two bolts and it says Carter. If I can figure out how to upload pictures to the site I will send pictures of the carburetor
OK, then. You've visually confirmed that it is a single barrel, so "we" all KNOW that the truck has been modified from original.I'll leave the tech response to those that know more about the lean burn system. Roger |
| Author: | Robin1983 [ Wed Nov 15, 2023 3:04 am ] |
Rodger thank you so much for your help. I have had nothing but problems out of this carburetor. I am going to do the lean burn conversion what carburetor do you suggest? |
| Author: | Robin1983 [ Wed Nov 15, 2023 3:07 am ] |
It has a one barrel Aluminum Intake |
| Author: | volaredon [ Wed Nov 15, 2023 10:23 am ] |
That model carb was always regarded as being better than the Holley that would have been stock. Maybe find another? |
| Page 2 of 2 | All times are UTC-08:00 |
