| Dual Disc Ram Clutches ***Looking for interested parties in a clutch/flywheel package https://mail.slantsix.org/forum/viewtopic.php?t=65283 |
Page 11 of 11 |
| Author: | Greg Ondayko [ Tue Nov 16, 2021 9:07 am ] |
| Post subject: | Re: Dual Disc Ram Clutches ***Looking for interested parties in a clutch/flywheel package |
Thanks Rick That is a good resource for sure. It does not give the spline length from a a fixed point. That is really the issue here.. I have some transmissions.... I will need to get to measuring them soon. Greg |
| Author: | captproblem [ Fri Mar 18, 2022 4:12 am ] |
Is Ram going to produce a single disc set up to fit its flywheel? I really don’t need a clutch capable of handling 600 hp or more. A single capable of 350-400hp 300-350 lbft of torque is more than strong enough and I’d like to keep the spinning weight down. |
| Author: | Greg Ondayko [ Fri Mar 18, 2022 7:53 am ] |
I think they produced one for a stock flywheel.... Lemme do some diggin' to see if I can come up with something... Greg |
| Author: | Greg Ondayko [ Fri Mar 18, 2022 9:52 am ] |
Here is some old info from AndyZ .. https://www.slantsix.org/forum/viewtopi ... ram+clutch That part # is now defunct. Maybe you can call them then see if they will make you one. or try Falcon Clutch in New york.. they remanufactured a very nice 9" mcLeod Unit for me a while back. If you give them your specs I am sure they can make a "beskpoke" clutch for you. Greg |
| Author: | captproblem [ Fri Mar 18, 2022 11:17 am ] |
I have one from Falcon. It is a 9.25 built to factory 340 specs. I also have a Ram Flywheel on the way that they say is drilled for their dual disc and a factory mopar 10” clutch PP. The 9.25 and 10 have the same bolt pattern so it should bolt on but I just like the added piece of mind of brand new clutch parts vs rebuilt. I’ll call them and see what the scoop is. Having not seen the 9.5 pressure plate for the dual system, I don’t know if that could work with a single disc without the center plate and second disc. |
| Author: | AndyZ [ Fri May 06, 2022 3:34 pm ] |
I just saw this. Sorry, been busy. If there are a few that definitely want one, we can ask for a group buy. Ram typically does their “special projects” in December or around the New Year. If we can get a number of participants, I will be happy to ask. AndyZ |
| Page 11 of 11 | All times are UTC-08:00 |
