| Covalt - "Project 65 Valiant" https://mail.slantsix.org/forum/viewtopic.php?t=35632 |
Page 113 of 125 |
| Author: | Andrew Shank [ Mon Sep 26, 2022 6:16 pm ] |
| Post subject: | Re: Covalt - "Project 65 Valiant" |
That's great Rick! With all the new found power you'll be back to Red Lighting in no time! |
| Author: | Rick Covalt [ Mon Sep 26, 2022 6:18 pm ] |
Friends stab you in the back faster than anyone! |
| Author: | slantzilla [ Mon Sep 26, 2022 7:21 pm ] |
Good job Rick! |
| Author: | Greg Ondayko [ Mon Sep 26, 2022 7:22 pm ] |
So the #2 venturi / jet install issue is that what you suspect was causing your high rpm flutter? |
| Author: | Rick Covalt [ Mon Sep 26, 2022 8:18 pm ] |
Yes instead of it pointing downstream and pulling fuel out, it was facing upstream and trying to shove fuel back up into the bowl. |
| Author: | Greg Ondayko [ Tue Sep 27, 2022 4:04 am ] |
Quote: Yes instead of it pointing downstream and pulling fuel out, it was facing upstream and trying to shove fuel back up into the bowl.
Congrats on that find! Sometimes it can be the smallest detail that we overlook and come back to find it with hindsight being 20/20. When you find it, it's the Ah-Ha Moment. |
| Author: | Dart270 [ Tue Sep 27, 2022 7:17 am ] |
Wonderful work and great to hear, Rick. Can't wait to see it fly at MM in a month! Lou |
| Author: | Rick Covalt [ Tue Sep 27, 2022 3:20 pm ] |
Quote: it's the Ah-Ha Moment.
I've had quite a few of those.Headed to the garage to put my 4.86 gears in. Hope I can put them in the right direction! |
| Author: | Rob Simmons [ Wed Sep 28, 2022 5:28 am ] |
Quote: Hope I can put them in the right direction!
| Author: | Greg Ondayko [ Wed Sep 28, 2022 6:24 am ] |
You can drag race in reverse with a reverse pattern valve body and it will all work correctly as you had planned! |
| Author: | slantzilla [ Wed Sep 28, 2022 7:41 am ] |
My Dad put the pig in an International dump truck upside down. Had 5 reverses and 1 forward. I did the same thing putting the carrier in a Cub tractor. International seems to like having diffs on the centerline so they go together either way. I don't think you can do that with an 8-3/4. |
| Author: | Rick Covalt [ Wed Sep 28, 2022 8:18 am ] |
With all your help I think I got it! Sure glad I installed an exhaust system for normal driving around the neighborhood. It sounds awful (the tone) but it made it nice while running up and down the road for 3 hours Saturday. Then last night I jacked the car up to do my rear end change, and literally in 5 seconds the whole thing drops off on the floor. I like it! Attachment: IMG_5963.JPG [ 76.02 KiB | Viewed 1300 times ] Attachment: IMG_5964.JPG [ 69.93 KiB | Viewed 1300 times ] |
| Author: | hyper_pak [ Wed Sep 28, 2022 8:22 am ] |
Pretty Cool Rick! What a clean modified '65! |
| Author: | Greg Ondayko [ Wed Sep 28, 2022 11:27 am ] |
Yes Rick's Car is Very Clean and a well thought out / put together car. You should come see it in person at the end of the month at Fairlawn, VA. Greg |
| Author: | Rick Covalt [ Sat Oct 01, 2022 9:17 am ] |
Good times today! Two of my Grandsons were in the garage with me. (Ages 11 & 15) They finished installing my conversion U joint, Installed my drive line, both axles and drums and wheels. And then they wanted me to fire it up (Open exhaust). They said it was loud. Look on their faces at 6000 rpm, priceless! |
| Page 113 of 125 | All times are UTC-08:00 |
