Electric Choke Conversion Kits
https://mail.slantsix.org/forum/viewtopic.php?t=12996
Page 3 of 6
Author:  super70bird [ Tue Nov 03, 2009 5:18 pm ]
I've installed this new electric choke on my 76 Dart (Holley 1945) and it's fine until I start the car - choke opens all the way right when I start it (40 degrees outside). I unhooked the hose to the unloader and then this doesn't happen. The unloader seems to pop the choke full open right at startup, not hitting the throttle at all. Does this sound like a fualty unloader? Or could it be hooked into the wrong vacuum port?
Thanks.
Author:  Reed [ Tue Nov 03, 2009 5:43 pm ]
Sounds like you need to adjust the linkage on the choke pulloff diaphragm. See this article for instructions on how to do it.
Author:  SlantSixDan [ Tue Nov 03, 2009 11:23 pm ]
The vacuum-operated device is the choke pull-off.
The choke unloader is a tang on the throttle lever that pushes the choke open when you floor the gas pedal, allowing you to clear a flooded engine.
Reed's right - it sounds like your choke thermostat and/or choke pull-off aren't adjusted correctly.
Author:  1974stepside [ Thu Feb 04, 2010 11:01 am ]
I just orderred an electric choke kit for my 1bbl carter bbs from carbs only. Do I need to remove the carb to set it up, if so are there any tricks i should know? Also as for the power, how do I hook it up to 12v source that is only on with ignition? Im a noob.
Author:  SlantSixDan [ Thu Feb 04, 2010 11:51 am ]
You needn't remove the carb. The kit comes with pretty good instructions, and you can re-use the existing choke power wire. If you don't have an existing choke power wire, follow the instructions that come with the kit as to how and where to put one in.
Author:  1974stepside [ Thu Feb 04, 2010 3:43 pm ]
Great thanks. Will let you know how it turns out.
Author:  1974stepside [ Wed Feb 17, 2010 5:40 pm ]
It works great! I hooked the power wire up to the wiper motor. Thanks for all the help and suggestions, great thread.
Author:  65 dartman [ Fri Apr 09, 2010 2:09 pm ]
Post subject:  1232 Choke Kit on a Super Six
I ordered and have received the 1232 electric choke for the super six that is in my 87 D100. Motor is (I believe) a 72 vintage with a Super six. Got to looking at it today seeing what I have to do to install it and don't see how the choke rod is going to attach to the choke mechanism on the carb. The choke rod is basically at a 90 degree right angle from the choke on the carb. Would anyone happen to have a photo or two of the 1232 kit installed. I do have the 87 FSM but doesn't seem to cover this retrofit.
Author:  SlantSixDan [ Fri Apr 09, 2010 2:20 pm ]
Everyone who gets the #1232 says the same thing, "I don't see how this could possibly hook up, the rod angle is wrong", etc.
Have faith. It will hook up to the Super Six carb's choke lever. Even though it looks wrong. Just follow the instructions that come with the kit.
Author:  1974stepside [ Wed May 19, 2010 7:47 am ]
Once warmed up and driving for over 30 minutes, I've noticed that when idle (at a red light) it idles very high. Not sure if I need to adjust the idle or the electric choke? Choke is fully open.
Author:  SlantSixDan [ Wed May 19, 2010 10:11 am ]
If the choke is fully open, your high idle isn't related to the choke. Your fast-idle cam could be sticking, the link between your fast-idle cam and the choke lever could be improperly bent (too short), or your idle speed could simply need adjusting.
Author:  1974stepside [ Wed May 19, 2010 1:09 pm ]
Yes, this occurs when the choke is fully open. I will try adjusting the idle speed. Thanks.
Author:  ESP47 [ Sun May 22, 2011 12:11 pm ]
Dan, will choke #1234 work on a Holley 6145 feedback carb on an 84 D100 w/lean burn?
Author:  SlantSixDan [ Sun May 22, 2011 4:18 pm ]
Yes, #1234 is correct for all 1945/6145 applications.
Author:  ESP47 [ Mon May 23, 2011 9:21 am ]
Thanks, I figured but wanted to make sure.
Page 3 of 6 All times are UTC-08:00
