| My 68 Barracuda https://mail.slantsix.org/forum/viewtopic.php?t=61820 |
Page 3 of 14 |
| Author: | DadTruck [ Fri Dec 28, 2018 6:12 pm ] | |||
| Post subject: | Re: My 68 Barracuda | |||
progress
| Author: | Dart270 [ Sun Jan 13, 2019 3:18 am ] |
Wow, I would not have guessed there was that much rust underneath on that car. Looks like they are being thorough! Lou |
| Author: | Rick Covalt [ Sun Jan 13, 2019 3:48 am ] |
Will be good for at least another 50 years , probably more! Boy, now would be the easy time to mini tub it too!! |
| Author: | DadTruck [ Sun Jan 13, 2019 6:33 am ] |
Quote: good for at least another 50 years
that is the plan,Quote: that much rust underneath
there was rust perforation on the: driver side floor pan, the driver side rear floor pan, the very bottom of the spare tire well the top of the passenger side front inner fender and the right rear frame rail there are aftermarket patches available for all of those and my initial intent was to have patches installed as I did not want to loose a year having the car redone. The shop I ended up going with is typically booked over a year in advance, however they had a window open up that fit my time frame perfectly, Dec of 18 to Jan of 19. I looked at pricing betwen doing the patches and simply replacing all with new, there was a difference in cost, but not like it was double. The shop is using all AMD panels, so that also added to the price. The torsion bar mount, firewall, radiator support, all cross bracing was still good, so I am just replacing sheet metal. I like the 'survivor' look of the exterior. It may have more of a 'day two survivor look' when I am completely done. |
| Author: | DadTruck [ Fri Feb 22, 2019 6:42 pm ] | |||||
| Post subject: | Re: My 68 Barracuda | |||||
The 68 B went into the shop Christmas Eve , got it back today, 60 days later,, What was not done can hold off till next winter, for now the plan is to get it back together and back on the strip. June is the goal. Two months worth of effort, (I know that the month of May is already committed to), lets see where that gets us.
| Author: | Dart270 [ Sat Feb 23, 2019 2:28 am ] |
Sounds and looks good, John. Hope to see you in VA or thereabouts... Lou |
| Author: | DadTruck [ Mon Feb 25, 2019 12:31 pm ] |
Quote: see you in VA
it would take a lot of home runs for that happen, get the car back together, new motor tuned - strip ready, and robust enough to then drive from Indy to nearly the Atlantic ocean in three months,,, but I am swinging. my realistic goal is to be running at Wilksboro the following month. |
| Author: | DadTruck [ Mon Mar 18, 2019 6:09 pm ] | ||||
Turned my new welding skill loose on the K frame. I had the K frame professionally cleaned / baked and blasted at a local parts cleaning location. They have a chemical tank big enough to set an entire car frame into. As I was interested in getting the grease and oil out of the metal they recommended an oven bake then a grit blast, so that is what was done. The K frame was clean-clean-clean when I picked it up. I purchased a K frame reinforcement kit from Firm Feel. The kit has cut pieces that reinforce the K frame at the: strut rod openings, lower control arm pins and boxes in the steering box mount and adds a support to the front side of the driver side engine mount. My K frame already had reinforcement at the strut rod openings so I did not use those two pieces. If a person has access to a band saw and about a 12x12 piece of sheet stock, make your own. With the exception of the strut rod and lower control arm disks, every thing requires a lot of shaping, grinding, fitting,,, but once they are sized and bent to fit, and welded, everything does get tied together. The perimeter of the K frame was spot welded from the factory. I went around the edges and seam welded it. If the weather holds I should get it painted later this week.
| Author: | Dart270 [ Tue Mar 19, 2019 4:40 am ] |
Looks like nice work. I may do a little gusseting and seam welding on the 64 Dart frame and K-frame while I have the engine out this time. Lou |
| Author: | DadTruck [ Fri Apr 19, 2019 5:45 pm ] | |||
working on the car every day,, sometimes twice,,, a lot to do, the intent is to make it the car I want, and that is: a car I can drive to the Slant Six Series drag races, a couple hundred miles or more. Think a Drag Week Car, but not that intense. So my car will need a sound system, installed dash speakers today. Cut the OE dash speaker out of its frame and installed a set of 3.5 inch JBL speakers. Used two layer plywood platforms as the speaker mount, chose that for torsional strength. with directional flexability,,, will add door mounted speakers, a decent receiver-amp,,, we shall see, its only a car,,, that I intend to drive in for X hours at a time, so the tunes need to sound right.
| Author: | DadTruck [ Wed May 08, 2019 12:39 pm ] | |||
finished up the gauge cluster * had the speedo gone through and re set to zero by Deluxe Speedometer Denver CO ** changed the amp meter over to a volt meter, kept the amp meter gauge scale just for looks *** installed a solid state 12v to 5v power controller from RT Industries **** installed an OE replacement tach from Classic Industries ***** polished the lenses with Meguire's Plastic Cleaner, ****** stripped what was left of the plated plastic with ez off over cleaner ****** painted the plastic with SEMS rattle can trim paint ******* used semi gloss black upper and lower plates from DMT to finish the front
| Author: | slantzilla [ Wed May 08, 2019 3:20 pm ] |
Looks great John! |
| Author: | Greg Ondayko [ Thu May 09, 2019 5:12 am ] |
Nice John, You wont need those speakers - they make the car heavier and you should be listening to the sweet sounds of slant snarl - It will play in any key you want! Greg |
| Author: | DadTruck [ Thu May 09, 2019 8:12 am ] |
Quote: It will play in any key
said the Music Man |
| Page 3 of 14 | All times are UTC-08:00 |
