| 198 block upgrade to 225 + super six setup https://mail.slantsix.org/forum/viewtopic.php?t=64542 |
Page 3 of 3 |
| Author: | radkoz [ Mon Jul 31, 2023 4:16 am ] |
| Post subject: | Re: 198 block upgrade to 225 + super six setup |
Hi Dan, After trying an aftermarket 318 BBD carb from China and facing the same idle stability issue (+new issue of flooding), I looked on the forum and found a guide to distributor rebuilding. It then pointed me to a service gear needing pin hole adjustment when replacing to cancel excessive play on the drive shaft - I remember I didn’t do that procedure. Rather than drilling new holes in the service gear, I simply have put back the original gear as it was in good shape. The idle issued has gone Now I have a spare Chinese BBD, maybe I will reuse some parts of it later to pimp my remanufactured Rockauto BBD (any articles/thoughts on mixing a 318 BBD with a /6 BBD?) . On this note thank you again for your and others assistance Rad |
| Author: | kesteb [ Wed Aug 02, 2023 8:01 am ] |
The A-Body never had a Super Six option, so there is no provision for the air hose off the air cleaner. On the F-bodies, the inlet was between the battery and the radiator, where it attached to a plastic pipe that had its inlet opening down by the bumper. The Super Six air cleaner is nothing more then a 318 air cleaner with a fancy decal. You could always substitute the base from a early '70s 318 air cleaner to get a more period correct look. Nice looking engine compartment. |
| Page 3 of 3 | All times are UTC-08:00 |
