| 1964 Dart Grüne Hölle Road Course AutoX Car IRWIN PA https://mail.slantsix.org/forum/viewtopic.php?t=60536 |
Page 36 of 39 |
| Author: | Greg Ondayko [ Thu Jan 02, 2025 7:05 am ] |
| Post subject: | Re: 1964 Dart Grüne Hölle Road Course AutoX Car IRWIN PA |
Hi Karl, thanks for following along. Some good tips there on the Cam Bearing Cutters. I will hopefully not need to try that, but it is possible that the quality and precision of new aftermarket parts could be questionable. You seem to have the same spirit as myself and some other close friends on the board here. Your recollections remind me of Seymour and Lou as they almost always drove to Drag Races, and somewhat long distances too (1,000's of miles) at times. I love driving the old cars and I will continue to do so as I can. A lot of those modern conveniences are not needed in my opinion. (I sometimes refer to them as engineered laziness) I have a purpose-built drag racing vehicle for such antics and I rarely have driven a vehicle to a drag race and then race it. But I hope to do much more in the way of track days HPDE and Auto X this year and future years! Cheers! Greg |
| Author: | Greg Ondayko [ Mon Jan 20, 2025 2:05 pm ] |
I dropped the Head off at the Machine shop today after work, instead of in the morning due to Road conditions. What a difference 8 hours and some sun and Salt can make for the road conditions. The Snow stopped falling, that helped too. I am going to get all of the seats and valves checked over while I had it this far apart. |
| Author: | Dart270 [ Tue Jan 21, 2025 6:18 am ] |
Cool stuff, Greg. That is amazing that exh valve contact. Gotta be that Mike's shop put mismatched angles on valve and seat - weird. Cool little oil P gizmo... Slant on, Lou |
| Author: | Greg Ondayko [ Tue Jan 21, 2025 8:24 am ] |
Yes and I thought a Jeffery head would have a 3 or 5 angle on the intake valve as well, but no single angle. Greg |
| Author: | slantzilla [ Sat Jan 25, 2025 8:33 pm ] |
Awesome work Greg! |
| Author: | Charrlie_S [ Sun Jan 26, 2025 3:24 am ] |
Had a message on my phone, that my 198 rods are done. 6 reconditioned with ARP bolts, and 12 others checked to see if they are salvageable after another shop screwed them up. Spent the day Sat working on the heat pump for the shop. Even though the daytime temps are getting into the 50's and 60's, the nights are going into the high 20's and low 30's. The shop doesn't warm up enough to make me want to work out there. The AC unit did work but the heat would not go to defrost mode correctly. |
| Author: | Greg Ondayko [ Sun Jan 26, 2025 6:43 pm ] |
Good Deal Charlie, Hopefully those rods will all size out correctly.
| Author: | Greg Ondayko [ Sun Feb 09, 2025 7:02 pm ] |
| Post subject: | 2/9/25 |
2/9/25: Some progress has been made. Last Week, I was able to do some cutting, grinding and welding on my semi-custom valve cover. Still quite a bit of work there to get things all done. ![]() ![]() ![]() Gasket all coppered up ready for an install: ![]() Lifters installed: ![]() Head installed and Torqued to Spec: ![]() The last time I had the engine together I was unhappy with the oil flow to the rockers and top of the engine. The only thing I changed on the last iteration in 2023 was the head bolts(studs). On the other performance engines with the ARP Head studs I have built ('69 Dart) and (the Ruster) I always turned or had a machine shop turn for me one of the studs down to the diameter of the stock head bolt so that the oil passage to the rockers would not be restricted around the ARP Stud, which is noticeably girthierer than a stock head bolt. I did not do that last time but I did this time, so hopefully I will be happier with the results. ![]() So except for the the Intake, Headers, some hoses and other bolt ons, the engine is complete, I set the Timing and Cold lash so that after priming the oil pump with no spark plugs and compression, I should be able to Put fuel to the carb and Fire it right up. One other thing that I did was begin to find out where and how much of the # 6 header tube I need to cut to use the Weber DCOE style EFI setup. I need to completely cut and then add some radiused length of tubing for the # 6 tube for my manifolds to work together as the intake also hits the #5 intake runner as I have removed half the diameter of the #6 tube already. No amount of just dinging it would work here, I would have closed up half of the tube or more. ![]() ![]() ![]()
| Author: | slantzilla [ Sun Feb 09, 2025 7:23 pm ] |
Great progress Greg! |
| Author: | Greg Ondayko [ Mon Feb 10, 2025 5:38 am ] |
Thanks Dennis, i am glad you are enjoying my documentation of the trials and tribulations here.Greg |
| Page 36 of 39 | All times are UTC-08:00 |
