| 1964 Dart Grüne Hölle Road Course AutoX Car IRWIN PA https://mail.slantsix.org/forum/viewtopic.php?t=60536 |
Page 5 of 39 |
| Author: | drgonzo [ Tue Jan 15, 2019 5:55 am ] |
| Post subject: | Re: 1964 Dart Grüne Hölle Road Course AutoX Car IRWIN PA |
That look great, better than new. |
| Author: | Greg Ondayko [ Tue Jan 15, 2019 10:23 am ] |
Photo trick.. Paint was still wet in that shot. It will be satin black. I am distracted by k frames in cars that are actually shiny. Greg |
| Author: | drgonzo [ Sun Jan 20, 2019 4:20 pm ] |
Wheels look great. About the same as the ones we had on my son's Maverick. |
| Author: | emsvitil [ Sun Jan 20, 2019 5:56 pm ] |
| Post subject: | Re: ¿You Mocking me? 1/20/19 |
Quote: Well I got all of the K Frame Painted and installed.
Got the new 16:1 Steering Box installed,...……..., Threw the 17x8 Mustang wheel on with a 245-45-17 Tire on it. Greg How are the arm exercises coming along? |
| Author: | Greg Ondayko [ Sun Jan 20, 2019 6:09 pm ] |
I am ready. Lots of lifting and tire changing keeps the upper body fit. Removing unneeded weight from the front of the car will help too! Got a Fiberglass hood and some other trick bits to get the front end lighter. Greg |
| Author: | Dart270 [ Mon Jan 21, 2019 4:43 am ] |
Looks great, Greg. I have always run spacers on those wheels (1/2 - 3/4") to get BJ and tie rod clearance. They are deep offset anyway, so a spacer makes sense. Lou |
| Author: | Greg Ondayko [ Mon Jan 21, 2019 11:04 am ] |
The FFI sway bar arrived today, So this week's project will include mocking it up and getting the tabs welded onto the lca's. Once that is done lca's will be removed, painted and reinstalled. Also putting together the dual circuit master cylinder and rebuilding the steering column. Greg |
| Author: | emsvitil [ Mon Jan 21, 2019 4:04 pm ] |
The closer you can get the tabs to the wheel, the more effective the bar will be...……... |
| Author: | Greg Ondayko [ Mon Jan 21, 2019 6:39 pm ] |
Right on! They are designed to line up about on the shock bolt area. I don't think i will be widening the bar. Greg |
| Author: | Dart270 [ Sun Jan 27, 2019 3:56 pm ] |
Those are nice looking sway bar tabs, and nice work on the LCAs. People will freak when we show up to a track day or autoX with a pair of Slant 6 64 Darts. Lou |
| Author: | Greg Ondayko [ Sun Jan 27, 2019 5:27 pm ] |
Thanks Lou. Those sway bar tabs were from speedway motors, but did not hit the lca in mock up. So I had some spare roll cage tubing that I cut about 2" off of to bridge the gap. Of course some other small mods needed to make it all work before welding. Greg |
| Author: | sixinthehead [ Sun Jan 27, 2019 6:55 pm ] |
I thought those extensions looked round. Nice engineering |
| Author: | emsvitil [ Sun Jan 27, 2019 9:01 pm ] |
Will that induce a twist in the lower arm since it's so far off the centerline? |
| Page 5 of 39 | All times are UTC-08:00 |
