| DrGonzo's 1963 Dart 225 https://mail.slantsix.org/forum/viewtopic.php?t=44333 |
Page 6 of 7 |
| Author: | Badvert65 [ Fri Mar 27, 2020 4:55 pm ] |
| Post subject: | Re: DrGonzo's 1963 Dart 225 |
[/quote]Is that a good place for the return spring to be mounted? Looks like engine torque would try to close the throttle on you. jus sayin.... |
| Author: | drgonzo [ Fri Mar 27, 2020 7:05 pm ] |
It is NOT a good place to mount it and it is not permanent. Good eye! |
| Author: | Rick Covalt [ Sat Mar 28, 2020 8:40 am ] |
I just thought the motor mount was torn and that was holding the engine in place! |
| Author: | Badvert65 [ Sat Mar 28, 2020 8:43 am ] |
Poor man's Rev Limiter....... |
| Author: | drgonzo [ Sat Mar 28, 2020 9:36 am ] |
I can't believe you guys haven't already seen the combination throttle return spring/torque strap. It's been around. |
| Author: | Badvert65 [ Sat Mar 28, 2020 10:32 am ] |
I have been a little out of touch with the TRUE racers for a while now. Keep all these tips and tricks coming. |
| Author: | drgonzo [ Sat Mar 28, 2020 12:27 pm ] |
I have abandoned experimental tech for the time being.
| Author: | Badvert65 [ Sat Mar 28, 2020 1:29 pm ] |
You went 'conventional'.... Is that allowed? |
| Author: | drgonzo [ Sat Mar 28, 2020 2:36 pm ] |
Quote: You went 'conventional'....
The fact that you are here says the same for you.
Is that allowed? |
| Author: | Badvert65 [ Sat Mar 28, 2020 4:17 pm ] |
Point taken. |
| Author: | Greg Ondayko [ Sat Mar 28, 2020 9:42 pm ] |
Is that a good place for the return spring to be mounted? .
Mine has been mounted in a similar fashion for many years on the hyperpack dart... never had any problems. Greg |
| Author: | drgonzo [ Sun Mar 29, 2020 8:07 am ] |
Really that set up didn't present any problems while driving and the reality of it is, throttle return springs are trying to close the throttle all the time. |
| Author: | sixinthehead [ Sun Mar 29, 2020 11:22 am ] |
All the extra 'Bigfoot' adrenaline at WOT easily overcomes a little extra spring tension |
| Author: | drgonzo [ Sun Mar 29, 2020 11:33 am ] |
Joe knows |
| Author: | drgonzo [ Sat May 23, 2020 4:46 pm ] |
Going up to Paradise tomorrow and see if the changes I've made help or hurt. Maybe I will run into Finnegan, but I doubt it. |
| Page 6 of 7 | All times are UTC-08:00 |
