| 1972 Dodge Colt https://mail.slantsix.org/forum/viewtopic.php?t=63924 |
Page 7 of 80 |
| Author: | slantzilla [ Thu May 14, 2020 6:57 pm ] |
| Post subject: | Re: 1972 Dodge Colt |
Mine has a fitting drilled into the front of the block and an external pump from the lower tank of the radiator. Mike used a sprayer pump, but a pump for the rear heater in a Durango or minivan works just as well, and is about 1/4 the price. https://www.ebay.com/itm/04-07-Dodge-Du ... 1362428779 I think Dorman has this pump at Autozone or NAPA for about $100 less. Then you can make your plate solid or drill the fitting into it like I did on my Daytona. |
| Author: | Will [ Fri May 15, 2020 3:09 am ] |
Looking Great! |
| Author: | Dart270 [ Fri May 15, 2020 5:38 am ] |
Nice work, Stan! Thanks for the water pump tip, Dennis... Lou |
| Author: | Rob Simmons [ Fri May 15, 2020 8:06 am ] |
The Challenger is set up like Dennis’. |
| Author: | Rob Simmons [ Sat May 16, 2020 6:24 pm ] |
So cool! |
| Author: | hyper_pak [ Sun May 17, 2020 6:01 pm ] | |||
| Post subject: | Re: 1972 Dodge Colt | |||
Figured out if I kick the front of the motor over a couple of inches, I could get the pump in. So I put all the stuff on the motor, put the front end back on with the hood and I have a 1/4 inch between the hood and the front breather. So I used the Offy valve cover and it has a pretty high standpipe. So if I cut a 1/4 inch off of that I will have plenty of clearance. First picture is everything installed and hood on, it fits! Now for the Headers....
| Author: | Badvert65 [ Mon May 18, 2020 6:44 am ] |
Will tilting the engine have much effect on the clutch and transmission linkage? |
| Author: | hyper_pak [ Mon May 18, 2020 9:38 am ] |
Badvert, the engine is at the 30 degree tilt as designed. The bellhousing is square with the frame, so all that stuff is right were it should be. The transmission rear mount is square to the rear crossmember. I am going to use a hydraulic throw-out bearing because I don't want to fabricate a bunch of linkage and rods in the close space I have. Is that what you were asking? |
| Author: | Greg Ondayko [ Mon May 18, 2020 6:23 pm ] |
Getter done. .... Looking Good Stan! Greg |
| Author: | slantzilla [ Tue May 19, 2020 10:11 am ] |
![]() Here's a picture of the headers Jeff Long built for my Daytona. You may end up doing something similar. |
| Author: | hyper_pak [ Tue May 19, 2020 4:36 pm ] |
Nice |
| Author: | hyper_pak [ Sat May 30, 2020 7:19 pm ] | |||
Mr. Burns sent me his last set of NA headers to see how they might fit. The good news is except for a couple of spots they fit pretty well. The bad news is they don't fit the Clifford Weber intake very well. At least 4 tubes would have to be massaged quite a bit. So thinking about getting the manifold from OZ and using that one. It looks like the runners are a lot straighter. Thoughts?
| Author: | slantzilla [ Sat May 30, 2020 7:47 pm ] |
I still vote for building a set that fit like you want. Pay once, cry once, done. |
| Author: | Rick Covalt [ Sun May 31, 2020 4:29 am ] |
That is what I am running Stan. They do give you a little more room. They are 1.5" longer I think. Mine had to be massage quite a bit. Cross section was quite a bit smaller than the Clifford. Casting was off pretty good as well. Runners were not all level with each other when you laid a straight edge across them. Good news was there was plenty of meat to open them up and straighten them out. . |
| Page 7 of 80 | All times are UTC-08:00 |
