It is currently Tue Nov 18, 2025 11:39 am
 Post subject: Thropar '64 Valiant
PostPosted: Sun Jul 25, 2004 1:31 pm
So here's the '64 Valiant I got last year through a movie project I was working on. Grandma's car, 170, 59k original miles, Vero Beach FL, bought from 2nd owner.
a few burnt valves, a 1bbl that coughed around corners, and the usual fried ammeter wires going through the dash melted and deformed...
The interior is red, in nice condition, i think it was redone partly, not sure though, it could be original
AM radio with blown speaker, aftermarket underdash AC unit blows cold after putting in a new condenser and some R-12$$$
here's the 225 being built at Chad's in Oviedo, he picked out some nice cam specs and we put together a nice motor. I did the porting on the head, keeping the stock size valves, i'll probably go to larger valves soon, i suppose Chevy 1.72/1.50
Here's the car with the movie paint job, color will probably change in the future when i do the paint for real (door jambs, engine bay, etc.) This is at Palmdale in CA, with the 225, supersix, 2 1/2" exhaust, 2.45 airplane gear running 18.5 @ 76
the car in LA amongst the most old cars I see in the US, LA has tons that are daily drivers, check the Ford wagon and truck... on the right side of my car is a 440 Challenger and a 360 Duster project going on...
after changing to an 8 3/4" rear (given to me! from friend Oddio in LA, out of his Duster with 40k original miles.. he has 3 mopars and lots of parts to share) ... bought a 741 case, open 3.55 gear, it picked up some quickness, best time after this was 16.7 @ 81 (BBD and stock ex manifold) The transmission is stock with an external cooler.
Mopar 6-1 header out of Chad's car, pre-dented. I got it JET-HOT coated for $200, which was pricey, but worth it! It is at least 20% cooler than other headers that I've run, I am totally sold on this coating.
So, this header DOES fit in the early A body, without major mods or anything. It fits like any other header on a car, you need to dent some tubes, and install carefully. It helps to have an engine hoist :wink: Chad helped me on that one. There have been no clearance issues, the steering works fine, it doesn't hang too low in the car, etc etc. I'm pretty stoked about the way it fits. I think there is even clearance for a Z bar and linkage for a manual shift trans. (T5 :twisted:)
So here it is now, I ran a 15.9 @ 86 the other night first time out with the Edelbrock 500, Clifford intake and header. That really allowed the cam and head flow to work, it was so choked up with the 2bbl and log manifold ex. It spins up to 6 grand (it'll hit the limiter on the MSD) but power is really only to about 5500-5700.
The motor needs some timing and advance curve tweaking, adjust the throttle (has a 1/8"squeeze more on the throttle not being used), transmission work, maybe bigger valves, 340 valve springs, battery going in trunk, maybe a Flowmaster instead of the "performance turbo" on it now...
also planned is the front end rebuild with offset UCA bushings, disc brakes, and a real alignment!
PostPosted: Sun Jul 25, 2004 7:15 pm
Wow, nice quarter times. Will it hold you back in the seat? It sure was in good shape when you got it. You're lucky!
82 D150-225/727
02 Dakota-3.9/5 speed
 Post subject: more Valiant info
PostPosted: Sun Jul 25, 2004 9:40 pm
Thanks, yeah, it seems to run pretty good, it'll push you back a bit once it get's breathing... I want to get it into the 14's, it may need the bigger valves and a better launching apparatus for that(trans situation) (stock converter)... for now, i'll try getting it to low 15's
the car was in great shape, original paint and all, so it was kind of a let down that they wanted it painted cheap yellow, but the paint job actaully held back a few little surface rust spots... there isn't much bodywork to do, it needs a valence panel in front, and a few little metal panels welded in,... underneath is perfect...
PostPosted: Mon Jul 26, 2004 5:04 am
Looking good. Now a converter, with some stall speed, and a little lower gear, in the rear, some fine tuning, should be in the 14's. Mile per hour shows its making power.
PS, what did you guy's, wind up with for a cam?
PostPosted: Mon Jul 26, 2004 8:59 am
hey Charlie, oh yeah you got the 170 short block from this car! we put in a Reed cam, top secret :wink: , dual pattern design, lift is in the 480's, duration in the 230's. It idles really good and is strong, my hat is off to Chad for picking some good specs out. Dennis at Reed may have fine tuned the numbers when they ground it down.
 Post subject: You Da Man
PostPosted: Mon Jul 26, 2004 2:00 pm
Nice Work, Thro! Now you have to get those discs on the fromt so you can stop that thing.
Then you get yourself back out to Cali so we can run.
Stay Claen,
oddio
That Jet coated header looks sweet!
 Post subject: Omg!!!!
PostPosted: Fri Jul 30, 2004 10:50 pm
:wink:
You let Putzie blink at your car?!?!?! Looks like things are going pretty good, just don't let him talk you into using 'Voodoo Juice'....
PostPosted: Sun Aug 01, 2004 7:06 pm
Sweet ride, Thropar. Keep up the excellent work and I hope we can meet sometime at a Slant race or something.
 Post subject: Hurricane thanks
PostPosted: Sat Aug 14, 2004 7:59 pm
thanks guys, it's coming along, so many other projects to really do it all right now
DI, i wont be running the voodoo anytime soon... i might get some laughing gas though!
Lou, would be great to meet someday and check out your wrenching...
In other news, hurricane Charley came REAL close to ruining my car, luckily my brother moved it out of harms way of fallen trees... i'm on vacation right now and will post a pic of the HUGE OAK TREE that fell in our backyard...
 Post subject: Slant 6 build up!
PostPosted: Wed Apr 13, 2005 11:05 am
Hey, nice build up on the slant.... good numbers. You mentioned the header is from Mopar.... I think I'll check it out. I have an original paint 73 Dart Sport with a slant 6 engine and have been going back and forth on wether or not to swap in a V-8 or stay with the six. Since it will my sons car someday I'm going to build the SIX. Any info you wish to share feel free to email me, I'm at edison_1962@hotmail.com and click the link here to check out my car!
www.cardomain.com/memberpage/818614
Bryan
PostPosted: Sat Nov 05, 2005 9:06 am
looks great, performs great, all you need now is a stall convert and she be runnin low 15's maybe 14's :lol:
Cuda Progress :D
The dart as it sits now :(
