It is currently Wed Nov 19, 2025 10:20 pm
PostPosted: Sun Dec 31, 2006 9:30 pm
Car Model: 1964 Valiant
Is the OEM aluminum 1 barrel manifold okay to use for EFI. Mine is the one piece non-welded casting. I'd like to send this out to have bungs welded in and a fuel rail made to match.
Is any shop recommended to do good work ?
Tim
PostPosted: Sun Dec 31, 2006 10:14 pm
I don't see any direct problems... question is, why bother with a one barrel manifold though? What throttle body are you planning to use? If your going to use the carb as a throttle body, how will you mount a TPS and possibly IAC?
I would try to get your hands on a cliffy/offy 4bbl unit to modify, that way you'll have more throttle body choices or at least room for expansion.
Check http://www.slantsix.org/forum/viewtopic ... old#123149 for more info.
