| harmonic balancer https://mail.slantsix.org/forum/viewtopic.php?t=2236 |
| Author: | V. Tedeschi [ Sun Jun 03, 2001 8:45 pm ] |
| Post subject: | harmonic balancer |
Where can I find a new harmonic balancer for my SL6-225? Mine came apart when pulling it off the engine and I don't feel it is usable. vmted@sprintmail.com |
| Author: | dschumers [ Sun Jun 03, 2001 9:38 pm ] |
| Post subject: | Re: harmonic balancer |
: Where can I find a new harmonic balancer for my : SL6-225? Mine came apart when pulling it off : the engine and I don't feel it is usable. There is a place in California called "Damper Doctor" that rebuilds them. If you use the "search" function, the address may be in an old post on here. aschumers@aol.com |
| Author: | Doctor Dodge (Doug Dutra) [ Mon Jun 04, 2001 9:15 am ] |
: There is a place in California called : "Damper Doctor" that rebuilds : them. If you use the "search" : function, the address may be in an old post : on here. If a quick way out is needed, I have a "pile" of good used ones for "cheap" I will need to know the year of the engine and where the timing mark is located. (BTW...Next time, use the correct damper puller to take these off, as you found-out, "jaw type" pullers just pull the outer ring off the damper) DD |
| Author: | dschumers [ Thu Jun 07, 2001 3:44 pm ] |
: Where can I find a new harmonic balancer for my : SL6-225? Mine came apart when pulling it off : the engine and I don't feel it is usable. I was digging around and found the address for Damper Doctors. 1055 Parkview Ave. Redding, CA 96001 aschumers@aol.com |
