It is currently Thu Nov 20, 2025 2:22 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 9 posts ]
PostPosted: Fri Jul 27, 2001 10:35 pm
Anyone wana take a guess?
Its on a "warmed up" fresh slant six i just picked up along with a full A-body duel system and tranny.
Other pixs of it
cralt@hackme.dhs.org
PostPosted: Sat Jul 28, 2001 8:13 am
Look for the ID number. I think it is stamped on the airhorn (the part where the choke blade is inside of). Then I or someone else can look it up in a Holley Carb book. I recently moved and don't know where my book is packed away right now.
See picture..
cfield@ll.net
PostPosted: Sat Jul 28, 2001 10:12 am
: Look for the ID number. I think it is stamped
: on the airhorn (the part where the choke
: blade is inside of). Then I or someone else
: can look it up in a Holley Carb book. I
: recently moved and don't know where my book
: is packed away right now.
The model number will be preceeded by the word "LIST" example: "LIST 1850" stamped on the side of the airhorn as shown.
PostPosted: Sat Jul 28, 2001 3:56 pm
: The model number will be preceeded by the word
: "LIST" example: "LIST
: 1850" stamped on the side of the
: airhorn as shown.
: DD
if i had to guess looking at it. i would say in the 390cfm to 450cfm range.
buddy_37@hotmail.com
PostPosted: Sat Jul 28, 2001 6:34 pm
: if i had to guess looking at it. i would say in
: the 390cfm to 450cfm range.
That's what I'd guess too. Probably a 390.
aschumers@aol.com
PostPosted: Sat Jul 28, 2001 9:10 pm
: airhorn as shown.
: DD
They don't all have "LIST" preceding the number. Some have "R" preceding the number.
cfield@ll.net
 Post subject: LIST 8007
PostPosted: Sat Jul 28, 2001 11:17 pm
Then under 8007 it says 1832
thanks
 Post subject: Re: LIST 8007
PostPosted: Tue Jul 31, 2001 5:03 pm
: Then under 8007 it says 1832
: thanks
I am pretty sure that 8007 is a model number for a 390 4bbl carb.
madsenl@caltech.edu
PostPosted: Wed Aug 01, 2001 5:38 pm
: I am pretty sure that 8007 is a model number
: for a 390 4bbl carb.
: Lou
Holley book says it's a 390, model 4160, vacuum secondary, single inlet, built especially for 6's and small v-8's.
pmvdlaan@picusnet.com
