| BBS https://mail.slantsix.org/forum/viewtopic.php?t=2471 |
| Author: | Mike P [ Fri Jul 27, 2001 5:59 am ] |
| Post subject: | BBS |
Just rebuilt my BBS-4286S. Run's great, but when braking into a corner ~20mph (ie. yeild) The engine will stumble, and stall. I restart on a roll in neutral an rev it up to clear it out and it's fine. I had the same problem before rebuild. Any info is appreciated. PS. The Car is a 67' Dart GT conv. with 225. Shop manual says this carb came on the 170. Should I have a different carb? What's best? Thanks. |
| Author: | Doctor Dodge (Doug Dutra) [ Fri Jul 27, 2001 9:17 pm ] |
| Post subject: | Re: BBS Problem |
: Just rebuilt my BBS-4286S. Run's great, but : when braking into a corner ~20mph (ie. : yeild) : The engine will stumble, and stall. I restart : on a roll in neutral an rev it up to clear : it out and it's fine. I had the same problem : before rebuild. : Any info is appreciated. : : PS. The Car is a 67' Dart GT conv. with 225. : Shop manual says this carb came on the 170. : Should I have a different carb? What's best? The float level may be a bit high try lowering it, like 1/8 inch (a lot but it will show you if that is the cause). I lower my float level untill I get some "starving" on high "G" corning, then I raise the level up a bit to get rid of that. DD |
| Author: | Chuck Rivers [ Sat Jul 28, 2001 12:50 pm ] |
: The float level may be a bit high try lowering : it, like 1/8 inch (a lot but it will show : you if that is the cause). I lower my float : level untill I get some "starving" : on high "G" corning, then I raise : the level up a bit to get rid of that. : DD The float may also be low, causing starving in the corners. If lowering doesn't do it, try raising it. Chuck webmaster@omnipages.com |
| Author: | Mike P [ Sat Jul 28, 2001 4:34 pm ] |
| Post subject: | Re: BBS Problem Solved |
: I tried some more driving techinques, and it does it on a hard, straight stop. Bowls in front, so fuel is moving away. I think to low.
Thanks guys PS. Is this correct carb for stock 225, or am I better off with a different with something else? Thansk |
