It is currently Tue Nov 18, 2025 10:31 pm
PostPosted: Wed Aug 20, 2008 5:58 am
Going to a fun event in Missouri this weekend called the HAMB Drags. Takes place at the Smokin MoKan Raceway this Saturday.
We're racing (and I use that term loosely) our 63 Valiant. Street gears, street tires and a strong little 225 (4bbl intake, cam, headers, etc...).
What kind of times would you think we can hit? I think I would be happy if we hit the 17's. Should be a blast anyways regardless of times.
Linder Tech.com
Bubba's Trailer Park
PostPosted: Wed Aug 20, 2008 6:16 am
Depending on tuneup and engine components match, somewhere between 16.80 and 19.00... :D
PostPosted: Thu Aug 21, 2008 6:08 am
Nice spread there. I'll be sure to post up a time when we get back. 8)
Linder Tech.com
PostPosted: Thu Aug 21, 2008 8:24 am
OK, 17.45... :wink:
PostPosted: Thu Aug 21, 2008 10:07 am
My 225 powered '67 Valiant 100 with stock cam, Holley 390 sideways on an Offy intake, ported head and a Chinese stock replacement exhaust manifold with 2 1/4" exhaust ran 16.86 once and will run 17.10 most days. The car is a 3-speed with 3.21 gears and 205/75R14 Sears Guardsman radial tires. Stock the car ran mid to high 19s.
PostPosted: Mon Aug 25, 2008 10:56 am
Well, we had an absolute ball running the car. Made 3 passes with a best E.T. of 18.93 @ 76 mph. The car ran great and pulled really well once it ran out a bit.
With that said the auto and low rear end ratio (which is unknown) made the car a pig with horrid 60 foot times (2.8xx). That rear end gear has to be near a 3.00 flat or in that vicinity. 3 speed auto and we never even wrapped up 2nd. :lol:
We drove 1100 miles at about 85 mph and averaged 20 miles to the gallon for the trip. :lol:
Linder Tech.com
PostPosted: Mon Aug 25, 2008 11:00 am
Four words: high stall torque converter
Nice job.
Also, make sure timing advance is 28 - 32 deg at max mech advance. Too much advance really kills power on the 225.
PostPosted: Wed Aug 27, 2008 6:47 am
I obviously want this car as a daily driver, but how does a stall do on a normal driver around town and such?? I could use some edumacation on that.
Linder Tech.com
PostPosted: Wed Aug 27, 2008 8:04 am
For any stall up to about 3000, it will not really make much difference at light throttle normal driving conditions. You will barely notice it. Then, when you stand on it, it will really GO. I was getting better than 20 MPG on my '68 Dart before EFI with a 3000 converter. FUN to drive...
I would shoot for a 2800 stall. Midwest makes a nice converter, as do several others. DO NOT spend less than $400, and make sure you get a unit that is rated for a Slant. If you buy a V8-rated unit, it will have to be rated at about 3600-4000, which will stall around 2600-3000 on a 225.
PostPosted: Wed Aug 27, 2008 9:16 am
Thanks Lou, I appreciate the input. 8) We've considered the same thing for our roadster with the Slant as well since they both have the same motor/tranny combo.
Linder Tech.com
PostPosted: Wed Aug 27, 2008 10:45 am
You will be amazed at the difference. Gains will be in the 0.5 - 1 sec range in the 1/4 if you tune it right after converter install. :shock: :o
Users browsing this forum: Ahrefs [Bot] and 9 guests
