It is currently Tue Nov 18, 2025 6:58 pm
PostPosted: Mon Aug 02, 2010 8:31 pm
ha! i guess we were too busy trying to keep it on the road!
current completed work list:
1) carb rebuild
2) timing chain and TC set, ALL of it
3) remanned radiator, all clamps and hoses
4) water pump
5) brakes
6) brake lines
7) master cylinder
8) shocks, front and rear
9) oil sending unit
10) fuel filter (metal)
11) ignition coil
12) alternator
13) starter relay
14) accelerator pedal bolt
15) engine loom
16) dash loom
17) motor mounts
18) valve lash
19) valve cover gasket
20) headlight switch
21) rotor
22) dist. cap
23) spark plugs
24) door pin
25) steel wheel replacement
26) front passenger wheel bearings
27) greased/adjusted steering box
28) bulbs
29) vacuum tree cap
30) wiper blades
getting a new bowl gasket tomorrow, and...she's a runner! guess the kid will have to go back to school after all.
some of those things seem very minor, but trust me, the tiny things gave us the worst grief....that .87 accelerator pedal bolt ended up costing HOURS of rewiring and labor (wire fire last week) and around $80, conservatively, for new alternator and starter relay as well as wire, connectors, etc.
there's no way this list can possibly convey what we have been through with this car (or emma, or marylin. just sayin.'). THANK YOU, NEIL!!!!!
1962 dodge lancer GT
PostPosted: Mon Aug 02, 2010 9:12 pm
thanks,
if it wasn't for josh,CJ,DI and bobby helping me and teaching me stuff I wouldn't of been able to help. A year @ my familys shop and a year @ wildcat helped also. but this is what it is all about, slanter's helping other /6 people.
I'm stoked as hell that Lola is back up and I'm very happy with all the progress. but they are never "done" it's always some little thing but it sure beats payments and these cars have style and soul. and your never gonna get with a new car. welcome to the community!
n
PostPosted: Mon Aug 02, 2010 9:17 pm
That's a big list ,well done. :shock:
DRIVE IT,DON'T HIDE IT
PostPosted: Wed Aug 04, 2010 9:14 am
yep...i keep going over everything that could go wrong at this juncture, and we've pretty much covered the bases. still desperately need a steering box and front end alignment (front end drift like you would not believe!), leaf springs are in order as well, but it may actually be time to start prepping her for some body work. and a new floor pan. and...and...and...:P
after all of the harrowing adventures we've had in her, i have come to the conclusion that cars are in fact sentient, and slants are the more intelligent of the breed. it was like the cars were communicating with each other...20 minutes after one got new brakes, the other would go down, but they were always there to back each other up and if we got stranded, it was close to home. though i won't be forgetting the 60 MPH 15 mile flat tow up 26 any time soon.
and big thanks to bobby and randy!
Users browsing this forum: No registered users and 27 guests
