the black sheep at the track
https://mail.slantsix.org/forum/viewtopic.php?t=28497
Author:  the black sheep [ Mon Apr 21, 2008 4:15 am ]
Post subject:  the black sheep at the track
hey guys and girls ...
here are my times and mods holley 4bbl warped headers mild cam ported head .. points dizzy oversize vavles .. 14"tyres auto 2000 stall 3.23 gears open center .. best of a 17.45 @82 mph ..
12 months later ... edelbrock 4bbl new headers free flowing exhaust .eletric pump and a quick tune on the way out . to the track .. 3.23 lsd (oh the car is daily driven over 320 miles a week .. ) 17.20 @85 mph .....
this year ..msd 6al, eletric dizzy heat shield under carb open k@n air cleaner stub snak new 10mm leads . 8" wide tyres . v8 rear springs and shocks . oh and most of all i`ve lost about 10 kg since last year .. so time ???? i am hoping for a 16.9 ish..
yours the black sheep :)
Author:  SV162 [ Mon Apr 21, 2008 7:54 pm ]
Well done mate. What model Valiant are you driving? just trying to get an idea of how much weight you're moving.
Your terminal speed suggests you should be doing better times than you are. Are you getting any wheel spin on the start? I've run a 16.37@84mph so I would of thought you'd be around the mid to low 16's with 85mph. Especially with the 3.23 LSD and the engine mods you've done. That 16.37 I did was with a 2.92 std diff. I've since put in a locked 3.7 diff which gave me a 15.58@87 but I'll soon be putting in a 3.23 LSD just to make it more streetable. Hopefully what I lose with the gear change I'll gain back when I finally :roll: install a 4BBL carb. If the gods are kind I might get a chance to run the 4BBL with the 3.7 diff, that might be fun. :D
Author:  the black sheep [ Tue Apr 22, 2008 1:30 am ]
Post subject:  re.. track times
hey wow
there are lots of ozzies getting around in here i don`t know about the traction issue.. but i am trying to get a vf sedan (1640 kg ) to do a 16.99 or quicker this year .. the diff is a little old and it mite be stuffing up a little . so i hope i can get a good hook up out of the hole . the main thing my slant has is awsome mid range 2200- 4500 so i think i may need a bigger convertor .. or a better cam the on ive got is a 25\65 409" lift ..
your loooking at loosing more waight ..
the black sheep
Author:  the black sheep [ Mon Jul 28, 2008 5:37 am ]
Post subject:  The Latest Runs From Mopar Sunday
HEY ALL
I WENT TO MOPAR SUNDAY
with the only major changes being the fitment of a 286 duration cam ..
and guess whats the best time of the day was a 17.18 on a 26`c day with 95% humidy it kill the prefomance of most cars .... the top end sped has come down to 82 mph i have got much better traction with the v8 rear springs ......i had a chat to a guy at the track running a vc valiant in to the 14.5s and he usees the same cam.. his advice was to check that is was dialed in correct;y ... could this be thecase ..
the balck sheep
Author:  Dart270 [ Mon Jul 28, 2008 6:37 am ]
Definitely degree in the cam. I do it every time now. There are MANY other factors. Good head work and a high stall converter will do wonders.
Also, make sure your timing advance is 26-30 deg total mechanical advance at 2800+ rpm (vacuum unhooked).
