| some one tryed to take me and my car out today https://mail.slantsix.org/forum/viewtopic.php?t=28522 |
Page 1 of 2 |
| Author: | MiDi [ Tue Apr 22, 2008 2:03 pm ] |
| Post subject: | some one tryed to take me and my car out today |
i got in my car this morning and drove around the block ....all the sudden $#!+ got weird. my rear lug nuts have been loosened!!! expect for one. that one broke off and my tire came partly off. ![]() this comes after my entire netwerk/internet was attacked by 4 seprate ip adddys. i had to replace 2 switches, reprogramme a load balancing router and 2 cisco switchs oh and reformat my main server. anyone close by have the parts i need to get my car running again? i'm also calling wildcat to see what they want for it also. |
| Author: | Joshie225 [ Tue Apr 22, 2008 2:17 pm ] |
Dang, that really stinks. You should be able to get the wheel stud locally pretty easy. What do you know about the IP attack? Have IP addys? |
| Author: | MiDi [ Tue Apr 22, 2008 2:18 pm ] |
yeah i got addys & host, as soon as i get my boxes back up i will return the fav. thanks josh i thought i was gonna have to replce the entire thing. i'll pull it now, how do i remove the old broken off stud? plus i am guess i shoudl replace them all .. right? neil |
| Author: | Joshie225 [ Tue Apr 22, 2008 2:40 pm ] |
You can knock the remains of the old stud in with a big punch and hammer. I usually pull new studs in with my impact wrench, a spare lug nut, some washers and plenty of lube. If the other studs didn't get too chewed up they are probably fine. If I were still in Portland I'd say come over and we'll get it fixed up. You're still welcome to come over and the offer of help still stands, but I know just how expensive it is in time and fuel to drive out here. We should talk about the other attack. Still have my number? |
| Author: | MiDi [ Tue Apr 22, 2008 2:50 pm ] |
i think i might have your digits somewhere, i kinda lost a ton of .txt files when i had to reformat my main server, i finally got it up and running today but i have a long way to go getting it config'd properly. i am looking at the service manual jpegs and i somehow can't figure how to get this part off: cause i need to pull it and hammer those studs out, i wanna make it to dusteridiots place so we can rebuild my bbd tomorrow. ![]() mmm yummy brake dust! |
| Author: | SlantSixDan [ Tue Apr 22, 2008 2:54 pm ] |
Dude! Somebody's out to get you! Wheel studs and lug nuts are still available on the general market. Find someone who stocks the Dorman brand: Stud: 610-083 Nut: 610-186 |
| Author: | MiDi [ Tue Apr 22, 2008 3:01 pm ] |
yes i realize that SSD, Prolly my ex. few years back she got into my loft and cleaned it out. i mean nothing was left, not even my 2 cats. |
| Author: | Joshie225 [ Tue Apr 22, 2008 3:23 pm ] |
You don't need to pull the axle to pound the stud out. If you're already going to DI's place just put it back together and drive to his place. Take a new stud and nut with you and he'll get you fixed up with a quickness. |
| Author: | DusterIdiot [ Tue Apr 22, 2008 3:30 pm ] |
| Post subject: | Yep... |
Quote: You don't need to pull the axle to pound the stud out. If you're already going to DI's place just put it back together and drive to his place. Take a new stud and nut with you and he'll get you fixed up with a quickness.
I got an impact, and a place on the other side of town that has a whole wall of dormann and wheel studs/ lug nuts...You're legal to have 4 lugs on, and as long as the 4 are tight and don't loosen... this will be a quick driveway fixit... (and something to do while we let your carb brew in the tank a bit... I have a couple of BFH's and an impact (and bigger wrenches)... we'll teach them to mess with us!!!! Hope to see you soon... if you're not comfy with driving that far, you can also take it to the closest tire shop/Les Schwab/etc... and have them replace it too... -D.Idiot -D.Idiot |
| Author: | MiDi [ Tue Apr 22, 2008 3:45 pm ] |
i got the doorman part and i am trying to get it in. i will see if i can make it down there. somthing else also seems wrong on the right side. someone worked my car over GOOD! i am now going thru it to make sure the dart and i do not perish on the way down. neil |
| Author: | MiDi [ Tue Apr 22, 2008 4:11 pm ] |
i just checked out the front driver side tire and found this: ![]() i couldn't get the stud in, so after i pick up and cash my final paycheck. i will limp down to salem. right now i am taking this tire down to les shawb to see if they will repair it under my warrenty. looks like both driver's side wheels got worked over good and proper. errrrrrrrr!!! |
| Author: | stephaniebrite77 [ Tue Apr 22, 2008 7:25 pm ] |
Hope you make it down here safe tomorrow. |
| Author: | THOR [ Wed Apr 23, 2008 8:45 am ] |
So find out who it was, I'll bring over a spare block and we can take turn bludgeoning them with it. That should make them feel the same pain that they made you and your car feel. As far as the server... well, Im sure we can come up with a good idea for retribution on that later on. Bludgeon Fest!!!! |
| Author: | dank10fenny [ Fri Apr 25, 2008 11:06 pm ] |
i drove my vlaint wit a broken stud for about a year. i busted out my glassblowin torch and heated it up nice and when to town wit a sledge and knocked it loose, then rotate to right place to get it out... |
| Author: | THOR [ Fri Apr 25, 2008 11:20 pm ] |
Well, all is good now though, we got her all fixxed up!!! |
| Page 1 of 2 | All times are UTC-08:00 |
