Flooding on Startup
https://mail.slantsix.org/forum/viewtopic.php?t=2990
Author:  JamesM [ Thu Dec 13, 2001 5:07 pm ]
Post subject:  Flooding on Startup
Have built up /6 using a offy intake and 625cfm Carter. Once started up the engine runs fine and takes the fuel, however, it always wants to flood at start up. Choke is locked open, carb leaned down, and without pumping gas prior to start up I get liquid fuel in intake. New carb which seems to perform fine after start up. Anyone have/had this problem? Any comments or help appreciated.
uscl@staffing.net
Author:  Doctor Dodge (Doug Dutra) [ Mon Dec 17, 2001 8:19 pm ]
Post subject:  Re: Flooding on Startup
: Have built up /6 using a offy intake and 625cfm
: Carter. Once started up the engine runs fine
: and takes the fuel, however, it always wants
: to flood at start up. Choke is locked open,
: carb leaned down, and without pumping gas
: prior to start up I get liquid fuel in
: intake. New carb which seems to perform fine
: after start up. Anyone have/had this
: problem? Any comments or help appreciated.
Sounds like a piece of dirt or other crud on the needle - seat. Take it apart, inspect and clean. Reassemble and recheck the float level.
It is not uncommon for a "new carb. to develop a "leaky" needle valve if it has been sitting on a shelf for a long time because the smallest piece of lint or dust stuck on the needle - seat sealing surface will allow fuel into the carb when it's not needed.
