| Piston L2125 info? https://mail.slantsix.org/forum/viewtopic.php?t=3110 |
| Author: | mark dingbaum [ Mon Jan 14, 2002 9:50 am ] |
| Post subject: | Piston L2125 info? |
Hi, Anyone recognize the L2125 number from the top of my pistons? I'd guess maybe a TRW piston? Flat top, no valve reliefs. Anyone have technical info on these? Compression height, forged/cast, etc? thanks in advance, mark mldingba@collins.rockwell.com |
| Author: | GTS225 [ Mon Jan 14, 2002 1:37 pm ] |
| Post subject: | Re: Piston L2125 info? |
: Anyone recognize the L2125 number from the top : of my pistons? I'd guess maybe a TRW piston? : Flat top, no valve reliefs. ************************************************** Yep, you're right. TRW pistons....is there any indication of the letter F behind the 5? I know that piston was offered in a forged version, but am unsure if the cast was a different number, or the only difference was the "F" designation. : : Anyone have technical info on these? : Compression height, forged/cast, etc? ************************************************** Doug might be able to help here, sorry. Roger GTS225@aol.com |
| Author: | Doug P. [ Mon Jan 14, 2002 6:34 pm ] |
: Hi Mark, I looked the L2125F pistons up in the TRW Specifications book. They are as followes: Comp. Dist. 1.752", Powerforged, 2-5/64" and 1-3/16" rings, .9011" pin dia. I hope this answers your questons. Doug : : Anyone recognize the L2125 number from the top : of my pistons? I'd guess maybe a TRW piston? : Flat top, no valve reliefs. : : Anyone have technical info on these? : Compression height, forged/cast, etc? : : thanks in advance, : mark Valient64@aol.com |
| Author: | mark dingbaum [ Tue Jan 15, 2002 6:36 am ] |
| Post subject: | Thanks! No message *NM* |
