It is currently Tue Nov 18, 2025 8:31 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
 Post subject: cracked manifold ear
PostPosted: Wed Jan 23, 2002 12:18 pm
greetings from the midwest. just picked up a 64 dart 270 with 28000 original miles on it. everything's immaculate except for a crack on the exhaust manifold ear. any suggestions? welding or replacement? ease of replacing it? cost?
any help appreciated.
jeremy
eprentiss@aol.com
 Post subject: Re: cracked manifold ear
PostPosted: Wed Jan 23, 2002 4:13 pm
Jeremy,
What do you mean by ear? Like where it mounts to the head, or where the two bolts at the rear of the manifold go through to connect the intake to the exhaust? I had one that cracked on the heat stove right along one where the two bolts go through. My uncle welded it for me with nickel rod, and it's holding up fine.
If you think it can be fixed, and the manifold doesn't seem to be warped or cracked badly, then go for it...just because perfect exhaust manifolds are hard to find anyway.
Patrick Devlin
: greetings from the midwest. just picked up a 64
: dart 270 with 28000 original miles on it.
: everything's immaculate except for a crack
: on the exhaust manifold ear. any
: suggestions? welding or replacement? ease of
: replacing it? cost?
: any help appreciated.
: jeremy
pwd22@drexel.edu
