It is currently Tue Nov 18, 2025 8:35 pm
PostPosted: Thu Jan 31, 2002 4:37 pm
I have a 225 slant six out of a 1966 HD D200 truck which I think has the shot-peened crank. I want to rebuild this motor for the drag strip. I pulled the motor out of the truck with the bell housing and clutch attached, because I couldn't get it off! This is a cast iron housing for the granny 4 speed trans with the starter down by the oil pan. Does anyone know if there is a hidden attachment bolt inside the clutch area on this bell housing? The motor has the same holes and bolts as a car, except for the upper right hand corner of the bell housing when looking at it from the backside. In that area there is a bulge on the bell housing where a car would have a bolt hole. I have hit the bell housing hard enough with a hammer and a pry bar to have loosened it if it were just the centering pins that were stuck. It really seems that there is a bolt holding that is invisible. Any help would be welcome. Jack in Kimball MN
mayalalang@cs.com
PostPosted: Thu Jan 31, 2002 4:56 pm
Yes, there are bolts on the inside of that big bellhousing holding it to the SL6. First drop-out the clutch and flywheel, then remove those bolts.
: I have a 225 slant six out of a 1966 HD D200
: truck which I think has the shot-peened
: crank. I want to rebuild this motor for the
: drag strip. I pulled the motor out of the
: truck with the bell housing and clutch
: attached, because I couldn't get it off!
: This is a cast iron housing for the granny 4
: speed trans with the starter down by the oil
: pan. Does anyone know if there is a hidden
: attachment bolt inside the clutch area on
: this bell housing? The motor has the same
: holes and bolts as a car, except for the
: upper right hand corner of the bell housing
: when looking at it from the backside. In
: that area there is a bulge on the bell
: housing where a car would have a bolt hole.
: I have hit the bell housing hard enough with
: a hammer and a pry bar to have loosened it
: if it were just the centering pins that were
: stuck. It really seems that there is a bolt
: holding that is invisible. Any help would be
: welcome. Jack in Kimball MN
