Car ran, died and came back to life
https://mail.slantsix.org/forum/viewtopic.php?t=31869
Page 1 of 1
Author:  john b [ Fri Oct 24, 2008 9:15 pm ]
Post subject:  Car ran, died and came back to life
73 Dart with stock electronic ignition.
Driving home from Los Angles, about 100 miles the car ran fine for 50 miles until I stopped in traffic. Car died, no spark. Towed car off freeway, doubled checked all connections I could find. Everything seemed tight and the car would still not start.
Walked a mile to the parts store, got test light. Got power at ballast resister, coil and every other place that I could think of to look. Tried starting it again and it fired to life about 2 hours after it originally died. Drove home, car ran fine. Has worked fine for the last two days.
I have doubled checked everything. Can't find anything wrong.
Any ideas?
Author:  SlantSixDan [ Sat Oct 25, 2008 7:30 am ]
Heat-induced failure of one of your ignition components. Control module, distributor pickup coil, or ignition coil. Works fine when it's cold, starts to fail when it heats up.
Author:  slantvaliant [ Sat Oct 25, 2008 6:58 pm ]
Another possibility: Rust and dirt in the fuel can temporarily clog the fuel filter, then fall off after a rest and allow a restart.
Author:  lincparts [ Sat Oct 25, 2008 7:44 pm ]
Post subject:  bulkhead
firewall bulkhead connector bad contacts, heat soak as it was hot as crap this week, the ghost of mopar wiring, dirt or rust in the gas tank
Author:  steponmebbbboom [ Sun Oct 26, 2008 2:49 pm ]
not as long as there's no spark.
throw away your testlight and buy a multimeter. keep it on the seat so that when your ignition system fails you can properly test the components. a test light will not allow you to do that.
you not only want to verify power, you also need to verify ground, continuity and resistance of the components.
